225 vs 245 tires
pros: wider is better. more tire, more grip. 245's also look a bit nicer
remember to go 245 /40
cons: price?
some people say the steering doesn't feel as precise. (though having owned both sizes, I disagree with 245 feeling numb)
cons: price?
I just had a set of BF Goodrich g-force T/A KDW (245/40/18) tires on my 8 and I am totally impressed. I've been through the canyon roads in Malibu twice now, and there is a huge difference from stock. Lots of grip and they look way better.
But do as Jedi say: if you switch from 225's to 245's, you should switch from a 45 series profile to a 40 series profile. This will ensure that you have a similar rolling diameter and the least amount of speedometer error.
I had to explain this to COSTCO b/c they didn't want to install a non-stock sized tire. I had to show them that the rolling diameter and height profile was nearly identical to stock for them to do it.
245's will also have more spring back when hitting the tight turns. So you are more **** to lose controll of the car if you are not use to sliding when thitttting them turns. The ones I had on 18"x8 with a 40 off set where fat tires and the side walls where soft.
So yea +1 with the 40 side wall.
Hi guys, can I ask a total noob question? I can't understand how you can chose from a variety of tire sizes like 225 or 245 for a wheel? Shouldn't there just be one possible size that reflects the width of the wheel? I mean it's obvious that's not the case or this thread wouldn't exist, but could someone explain why? Thanks all!!
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
