Engine miss problem
Old Feb 24, 2009 | 08:27 PM
GeoffJ's Avatar
Engine miss problem
Hiya,
My cars been getting slight intermittent engine miss problemz at low rpm and idle speeds. Any ideas would be of use, thanks!
Regards,
Old Feb 24, 2009 | 08:30 PM
is it misfiring?
If so, most likely bad coils , plugs, or wires.
Old Feb 24, 2009 | 08:32 PM
GeoffJ's Avatar
thanks for quick reply..will further look into it. :D
what exactly is the car doing?
Old Feb 24, 2009 | 08:33 PM
thisllub's Avatar
What fuel are you using?
I find low octane fuel can cause flat spots.
Old Feb 24, 2009 | 08:42 PM
GeoffJ's Avatar
shell's, V-power............or MOBIL's high octane.
Old Feb 24, 2009 | 09:34 PM
GeoffJ's Avatar
yeah engine tends to misfire at idle speeds, any ideas on what likely causes this would be.
Is it a possiblity its to do with the seal? being paranoid lol.
Old Feb 24, 2009 | 09:38 PM
misfires at idle?
does the engine sputter? does the car shake a bit when it 'misfires'?
Usually misfires happen under load and at higher rpm's.
Could you describe in detail exactly what the car is doing at idle? is the Check Engine light on or flashing?
Sorry for all the questions, just trying to rule things out and help diagnose your car from the other side of the planet.
Old Feb 25, 2009 | 04:05 PM
GeoffJ's Avatar
yup. At idle speeds, then gets a little rough, as u accelerate the roughing fades.
Old Feb 25, 2009 | 11:07 PM
Cromax's Avatar
Buzz Buzz Buzz
It's normal for the car to pop and burble when you first start it though.
If it's happening all the time (even after driving around a bit) it's either your spark plugs, wires, or coils.
Do you have any flat-spots about 4-5000rpm?
Old Feb 25, 2009 | 11:40 PM
laythor's Avatar
I zoom therefore I am.
don't mistake the pop of a normal rotary at idle to a misfire... you'll know if it's a misfire if you lose power in the 5k range like Cromax has said. I love the pop pop pop the 8 makes in the low revs.
Old Feb 26, 2009 | 12:49 AM
takahashi's Avatar
If you have a early year model or you have vibration shake in your gear stick, then check the sagging engine mounts.
Old Feb 26, 2009 | 04:26 PM
GeoffJ's Avatar
gear sticks, fine....it might be just what cromax said.. it does somewhat go pop, pop.....................haha
Old Feb 26, 2009 | 05:42 PM
mikeyr's Avatar
i need a new photo
Geoff,
I'm still running the original plugs and coils at 56k but have spares (ready to change out). my problem was leads.
I put Magnecor leads on and my "rough idle" reduced by 95%. Even the missus commented unprompted! I'd checked the factory ones were well connected so must have just been poor quality.
Good luck
M
Old Feb 26, 2009 | 06:12 PM
GeoffJ's Avatar
very nice, I'll hopefully be able to look into this next week when i have the opportunity.
Thanks,
vapor2
Nov 3, 2020 03:38 PM
Skyl3r
Dec 2, 2019 04:51 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
Belalnabi
Jul 17, 2015 07:48 PM
