gap? is there a " best " gap reccomendation.
Old Feb 24, 2009 | 01:00 PM
peregrinus's Avatar
I Didn't do it!
Spark Plug Gap Specification
Standard [both]: 1.15mm-1.25mm (0.046-0.049in)
Maximum: Leading 1.5mm (0.059in) Trailing 1.4mm (0.055in)
Thanks to Go48
ok so this is what it says for gap, what exactly does this mean, where is the " sweet spot " to gap plugs at, i have the laser iridium plugs from fluid motorsports.
i don't wanna have to pull these bitches out twice if i dont have too lol.
ill check back in here once i get the car on a jack and the wheel off.
Old Feb 24, 2009 | 02:18 PM
MazdaManiac's Avatar
You can't "gap" the current RX-8 leading plugs (no ground bar) and shouldn't bother with the trailing.
Old Feb 24, 2009 | 02:22 PM
iridium plugs should be the OEM NGK's, correct?
If so, no gapping at all required. Just install them
Old Feb 24, 2009 | 02:23 PM
peregrinus's Avatar
I Didn't do it!
thats what i ended up doing. thanks jedi now i just have to " de-flood " and hopfully this solved my problem, my old plugs were pretty bad.
I can just hold down the gas pedal and crank it, correct? instead of pulling fuses etc..
Old Feb 24, 2009 | 02:26 PM
mash pedal, crank.
good luck
Old Feb 24, 2009 | 02:28 PM
peregrinus's Avatar
I Didn't do it!
thanks, i'll be ding this soon as the battery is recharged. -10F for a week + being flooded and unstarted for a month = no battery left haha
Old Feb 24, 2009 | 03:21 PM
staticlag's Avatar
The Professor
Be sure to crank it a few times without the plugs in to get all the fuel out or you'll end up ruining the new plugs also.
Old Feb 24, 2009 | 03:42 PM
Old Rotor's Avatar
Thanks to Go48
A NA engine should have a gap of 0.048in and when you replace it in about 30K miles it will be at about 0.049in.
Old Feb 24, 2009 | 04:01 PM
peregrinus's Avatar
I Didn't do it!
i cranked it for about 10 seconds with the plugs out, and ive probably done it for a good 30 seconds since i put everything back in, im giving the battery one last full charge and im going to go for the goal hopfully lol
Old Feb 24, 2009 | 04:07 PM
peregrinus's Avatar
I Didn't do it!
ok well i let up on the gas just for a second, and it almost cought, but i think i need to keep cranking it with the gas pedal to the floor, apparently there was alot more gas then i had anticipated lol
Old Feb 24, 2009 | 04:11 PM
peregrinus's Avatar
I Didn't do it!
would hooking up a jumper cable to another running car give me a better ammount of " cranking " time, rather than just recharging my battery for 2 hours everytime it dies?
Old Feb 24, 2009 | 04:19 PM
Nubo's Avatar
Lubricious
Stop torturing your battery. You need to improve the compression. About 15CC of the fluid of your choice into each of the 2 intake manifold "nipples" should help your starting attempts. I used motor oil when mine flooded -- per shop procedures. Some people use ATF. Be prepared for lots of smoke.
Or, you could get a push-start.
Old Feb 24, 2009 | 04:23 PM
peregrinus's Avatar
I Didn't do it!
battery is toast anyway, soon as im back at work car is getting a new battery, i just cant afford to go drop $100 on a battery right now lol ( im laid off work for winter )
besides, its snow and ice here, in order to get pavement a push start would work on i'd need to push it 10 or so blocks, to somewhere with heavier traffic.
and im stuck in a steep driveway. lol doesnt leave me many options, i might have to pull the plugs again, and crank it a few more times, see if it helps.
Old Feb 24, 2009 | 05:37 PM
peregrinus's Avatar
I Didn't do it!
woo, getting there, it ALMOST started, i think one or two more tries will do it.
Old Feb 24, 2009 | 05:59 PM
c'mon peregrinus, YOU CAN DOOOO IT!!!
(name that movie)
AJ's Shinka's Avatar
Enthusiast
Well I gapped mine due to one of these DIY and it gave me moar power. Now I am back to a new set ungapped, it is slower now. I think I will throw the old set back in. Muahaha!
Old Feb 24, 2009 | 06:14 PM
peregrinus's Avatar
I Didn't do it!
I am kicking myself in the *** right now, it FINALLY started, ran for like 2 seconds, and then i dunno if its because i gave it gas, or because i didnt give it gas, but it died, and reflooded.. *cries* lol
i re-confirmed the plug wires were properly plugged in, and in the right order.
I know it runs now, so it must just be a flooding issue? and not a blown motor, but, I'm sure it hates me now, and its probably flooded horribly now.... blaaahh
Old Feb 24, 2009 | 07:08 PM
peregrinus's Avatar
I Didn't do it!
YES!, hahahaaaaaa got it. the car is a whole new monster now.
the ignition must have been **** since i bought it, its revs TOTALLY different.
Old Feb 24, 2009 | 08:14 PM
grats!
ktec
Jun 26, 2021 10:18 AM
Sifu
Aug 30, 2015 10:51 PM
Jazzmeson
Aug 30, 2015 02:23 AM
Jazzmeson
Aug 2, 2015 09:49 PM
Red Ryno
Jul 24, 2015 09:06 PM
