Quick question about deflooding
Old Feb 23, 2009 | 04:17 PM
NiGhtRx8er's Avatar
Ive been trying to deflood my my engine for days. today i was cranking it(6-10 seconds) with the pedal all the way down over and over and I want to know if that is bad for the alternator because i hear some kind of clicking.
Old Feb 23, 2009 | 04:21 PM
dmc27's Avatar
doin' the bull dance
There's a method in the owners' manual and a method in the DIY section. Have you checked those? I can't remember it from waaayyy back when I read through the book, but I don't think just cranking it is the solution. You're probably destroying the starter.
Old Feb 23, 2009 | 07:17 PM
Phi's Avatar
Phi
Phi
make sure you clean out the spark plugs too.
Old Feb 24, 2009 | 11:13 PM
clmantis21's Avatar
have you tried push starting it? I did and it worked for me once. A different time it didnt, but I got a buddy of mine with a truck to pull start me and it worked. Just put the tow hook on and strap on and have someone pull u to about 20 mph... (I believe) and dump the clutch then. That method should work just fine.
If you are still under warranty, call roadside and have them deflood it at the dealer.
There is also the fuse removal method, but that didnt work for me... so I dont know about that. My best advice is the pull start method.
G'luck!
EDIT: just realized from your sig you are AT? hmm....
Last edited by clmantis21; Feb 24, 2009 at 11:16 PM. Reason: edit: just realized from your sig you are AT? hmm....
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
yankeepicker
Sep 11, 2015 05:42 PM
TJSiegrist
Sep 10, 2015 09:29 AM
Rupanrx
Sep 4, 2015 06:44 AM
