RPM's Gauge help..
Old Feb 23, 2009 | 11:10 AM
SilverRenesis's Avatar
RPM's Gauge help..
I have a question. Lately when im on the road and i stop at a light, sometimes i notice the RPM hand go down and up a bit.. what could this be?
Old Feb 23, 2009 | 11:32 AM
Old Rotor's Avatar
If you go to the rear of the car(at idle) do you hear a slight miss from your exhaust?
Old Feb 23, 2009 | 12:51 PM
a/c kicking on and off?
could be a bad neutral switch
Old Feb 23, 2009 | 01:36 PM
No, I dont ever use my ac...
Old Feb 23, 2009 | 02:00 PM
Im starting to wonder if the Spark plugs could be the cause...
Old Feb 23, 2009 | 02:35 PM
when was the last time u changed ur coils and sparks then ?
Old Feb 23, 2009 | 02:39 PM
I havent changed any internal engine parts since I bought the car, which I bought with 47k on it, now Is about to go into 50k,
Old Feb 23, 2009 | 03:25 PM
Hmm, do u know if the previous owner changed it at all ?
Its important because, if the previous owner has NEVER changed them, you should change it out ASAP.
Old Feb 23, 2009 | 04:59 PM
ryanalexander4's Avatar
- Ryan Alexander -
Tachometer - an instrument that measures the rotation speed of a shaft or disk, as in a motor or other machine. The device usually displays the revolutions per minute (RPM) on a calibrated analog dial, but digital displays are increasingly common. The term comes from Greek Ταχος, tachos, "speed", and metron, "to measure".
Old Feb 23, 2009 | 05:11 PM
Hoss's Avatar
Sorry to threadjack here, but a sort of related question...
Can you do any damage to a rotary motor by not changing the plugs every 10k miles? I know this is the suggested protocol, but if you wait until you start to see the signs of deteriorating plugs will it cause any harm? Other than possibly flooding the motor?
Also, is the spark plug life expectancy shorter on the rotary motors due to the oil consumption?
Old Feb 23, 2009 | 05:33 PM
hakuna matata!
/\ 10k might be a tad overkill.. 25k or so you will need to check them over though.
if the ignition system is not up to snuff you're not combusting completely and that will lead to carbon buildup.
Old Feb 23, 2009 | 05:34 PM
Old Rotor's Avatar
You can under normal conditions (NA engine) get 30-35K miles out of the OEM-NGK plugs. We have had some cars here go over 50K but you will feel some hesitation when they get worn. If they are the cause of the engine miss firing then you have gone as far as you want to go! Rotary engines fire more often thats why they ware out sooner.
Old Feb 23, 2009 | 05:43 PM
Hoss's Avatar
Thanks for the explanations
I have been wondering because I am having some long starts and according to the local stealership they have already performed teh TSB relating to this. I have been considering changing the plugs, but the car seems to be running perfectly fine ATM
Old Feb 23, 2009 | 05:45 PM
hakuna matata!
Long starts can also be attributed to the ignition coils.
Old Feb 23, 2009 | 06:48 PM
Hoss's Avatar
I had considered that as well, was hoping that those had been replaced with the TSB, but I am doubtful. Are the coils difficult/expensive? to change?
Old Feb 23, 2009 | 09:31 PM
Old Rotor's Avatar
The coils are $25-30(each and there are four of them) and easy to change, a good time to do the spark plug wires too( I got the OEM ones for less then sixty dollars.......
Old Feb 24, 2009 | 05:55 AM
DOMINION's Avatar
I don't buy Kool-Aid
I had the samething. Time for a tune up man. Get new coils spark plugs and spark plug wires. Save your self the money and change them your self. I changed them all in about one hour. Not bad.
Old Feb 24, 2009 | 11:50 AM
docgatorx8er's Avatar
TeethNThings.com
It is very easy to change the plugs and the coils BUT be sure you have someone around with you who knows what they're doing the first time. If you mess up, it's not pretty. Gotta watch the leading trailing thing VERY carefully. But it's not complicated.
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
D13
Oct 1, 2015 07:55 AM
tommy26Germany
Sep 29, 2015 10:33 AM
