How I cleared my tail light
Old Feb 20, 2009 | 02:39 PM
pieter3d's Avatar
After some heavy rain, my right tail light would get water in it and get fogged up. I had it fixed under warranty. This year my left one started, and warranty on that was up, so I did it myself:
- Pull the light out
- carefully peel off the foam rubber gasket without tearing it. It costs like $50 so be careful. I noticed some parts had already let go, that's probably how water was getting in.
- clean as much crap off as you can
- glue it back on with some silicone sealant, or equivalent
- drill a tiny drain hole in each black plastic shroud around the lights, but not into light's body. Its the plastic between the backside and the gasket. That way if water does get in there, it won't get high enough to enter the light.
- Reassemble once dried.
I had a fair bit of water in mine, and it having a heater blow on it wasn't going quick at all. I ended up pouring a little more water in, swirling it around to get most of the residue off the lens, then using a straw and just sucking it all out. The final moisture just evaporated after a few hours.
Old Feb 20, 2009 | 02:51 PM
Jon316G's Avatar
Grasshopper
Drilling tiny holes did the trick for me too.
Good job.
Maybe this should be in the DIY section?
Old Feb 20, 2009 | 07:51 PM
yurcivicsux's Avatar
ya did the same....take off ....drain....blow dry.... re seal with silicone.
fixed the problem.
I was so relieved.
Old Feb 20, 2009 | 10:20 PM
Black RTV on new gasket FTW.
Old Jul 21, 2009 | 09:34 PM
NdownIwardN's Avatar
Adam Rincon
i'm having this problem with my left tail light, i understand what needs to be done to get rid of the moisture but how do i remove the light itself?
Old Jul 21, 2009 | 09:46 PM
derek54's Avatar
unclip the trunk plastics by pulling the middle piece of the rivet, and then with that pulled. pull the rest of the rivet out. (i believe one of them you have to screw)
when you have access to the back of the light. untwist each light bulb. it should be only a quarter turn and they'll pop out. then there will be one left. the far left wire. which is an LED i believe. there will be a grey foam casing a little further down the wire. you'll want to pull that foam back and unplug the connection.
then all you gotta do is take of the bolts with a 10?mm wrench.
Old Jul 21, 2009 | 09:48 PM
... I have a DIY on this people ...
search ...
Old Jul 23, 2009 | 05:16 PM
04RX8man's Avatar
Rotary Powered Countryboy
^I think ppl forgot what search is!....maybe the mods should make the search button like 10 times bigger so you can't miss it!
Old Jul 23, 2009 | 06:27 PM
butt then no one will read any of the New threads because the search button is too big.
Old Jul 23, 2009 | 07:42 PM
04RX8man's Avatar
^ok maybe you get the big search button for a predetermined amout of log in's then it goes back to normal....
Old Jul 23, 2009 | 07:44 PM
rodjonathan's Avatar
silent assasin
^ lol we are getting more and more threads which are pointless coz all you need to do is searh a little lol that being said drilling worked fine for me
Old Jul 24, 2009 | 12:45 AM
JRTomlinson's Avatar
And with a little searching, we come up with...
TSB 09-005/09 WATER IN REAR COMBINATION LIGHT
http://www.finishlineperformance.com...05-09-2055.pdf
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
erikcamacho15
Sep 12, 2015 11:23 AM
