Can Auto8 install LSD?
Old Feb 15, 2009 | 12:37 AM
laulongfei's Avatar
laulongfei
I was wonder if Auto8 does it have LSD or just only a manual thing? I wonder if a Auto8 can also turn into a drift project.
Old Feb 16, 2009 | 09:23 AM
JTtheDude's Avatar
Depending on the model it might have LSD already. The base models are the only one's that don't have LSD I think. Drifting it is another story, I don't know, you have no clutch control so it makes it difficult but it probably could be done to an extent. it just doesn't have enough power to get the wheels spinning unless you get the tires wet or have boost in some way.
Old Feb 16, 2009 | 06:26 PM
mdw1000's Avatar
I'll snap his neck.
Depends on the trim level on whether it has it or not. The base does not have it, and I don't remember what trim it started at. The GT definitely has it.
Old Feb 16, 2009 | 07:13 PM
laulongfei's Avatar
laulongfei
well than can i install one?
i wonder if some one can answer my other thread about the rear brake too.
Old Feb 17, 2009 | 08:14 AM
JTtheDude's Avatar
I would think it could be installed unless the rear differential is different from the other models in some way other than not having LSD. I'm not too sure though.
Old Feb 17, 2009 | 08:30 AM
09Factor's Avatar
Original Turbo 'd Auto !!
The rear pumpkin is swapable and the LSD started at the "sport" model. You can get the tires spinning by incressing the stiffness of the rear sway and less grippy tires.
Old Feb 17, 2009 | 11:50 AM
laulongfei's Avatar
laulongfei
Thanks again 09Factor for you knowledge, so i can just buy a LSD and put it in with out doing any mod right?
Old Feb 17, 2009 | 09:29 PM
mdw1000's Avatar
I'll snap his neck.
Check with mazmart to make sure (and buy it from them). I think there might be something slightly different about the diff for the AT. I thought Paul said they had to use an AT diff when they built my new one for me.
Old Feb 17, 2009 | 10:04 PM
laulongfei's Avatar
laulongfei
thx bro! i probably ask him when i am ready to install that, for now i just want to focus install turbo, and just an hour ago some fool hit my car errrr...
Old Feb 27, 2009 | 02:08 PM
ferrocene's Avatar
ohio gozaimas!
I'm interested in the LSD. I'm still reading up the differences between the two. What type of diff is on the stock car? Is it considered an open diff?
Is a LSD always better in all cases? Still reading up on these units.
Old Mar 10, 2009 | 08:25 PM
winddude's Avatar
So Awsome, I am the STIG!
Its very easy to get the wheels spinning rev it up a little bit in nutral then drop it into gear.
Old Mar 11, 2009 | 06:54 PM
ferrocene's Avatar
ohio gozaimas!
I have read that a neutral slam is the fastest way to destroy an automatic.
Old Mar 11, 2009 | 09:23 PM
WTBRotary!'s Avatar
Drummond Built
Lol you dont even have to read about it to know that... Honestly guys think about it... Hmm lets rev it up and drop it in gear... this isnt a Manual... the 8's transmission is already fragile let alone the auto's. Id be suprised if you didnt have the tranny in your lap the first or second time...
Old Mar 11, 2009 | 09:31 PM
dshiznit1489's Avatar
Formerly Polak Graphics
Please go buy a Honda Civic.....
Old Mar 11, 2009 | 09:34 PM
WTBRotary!'s Avatar
Drummond Built
flame... hahah back on topic yes you can install a LSD to a base model 8. I dont know the mechanics to it but i know you can...
Old Mar 11, 2009 | 10:37 PM
laulongfei's Avatar
laulongfei
I think that is the reason why he is considering doing 4sp swap 6sp, because he is been doing the neutral drop in D mode.
Old Apr 6, 2009 | 01:14 AM
MrBuddhalicious's Avatar
wow a neutral drop!? honestly, who taught you how to drive? My A/T 8 sometimes can spin out and there has been the occasional drift on a turn...got to love that ability to press the T/C button, slap it into 2nd and floor it and feel the car slide on out a turn. mmmmmm
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
