Squeal at idle/low rpm
Old Feb 13, 2009 | 02:49 PM
JTtheDude's Avatar
What's up everyone, got a question on a 05 AT 4port with 80K miles. I'm having a squeal noise when the rpm's are at idle or drop to the 750 mark. If I raise the rpm to around 1K or higher it goes away. I get a quick chirp/squeal when I put it in Drive or Reverse from Park or Neutral while I'm on the brake, if I put it in Drive from Neutral but be slightly on the gas (around 1000-1300 rpm or so) it won't do it. When in Neutral I don't hear it but sitting still in Drive it will be there. I've read several posts about people having a chirp at startup, I don't get it at startup or I'm not hearing it if it's happening at that time. Those issues pointed to some kind of jet air nozzle and timing during cold startup and I was wondering if my problem could be related to the same jet air nozzle. I was also thinking it could be the accessory belt? I JUST replaced plugs/coils/wires last week. It is time for an oil change and that is happening this weekend. Any idea's or suggestions?
Old Feb 13, 2009 | 03:07 PM
laulongfei's Avatar
laulongfei
you mean rattling when the car not in motion or reverse, and rattling stop when its neutral?
Old Feb 13, 2009 | 03:20 PM
JTtheDude's Avatar
Yes however it's not really a rattle but more of a squeal like if you started a car with a belt that slipped, that kind of sound. Doesn't happen when moving or in Neutral, only in D or R.
Old Feb 13, 2009 | 03:25 PM
Silver06's Avatar
Zoom Zoom....
Check the accessory drives & belts.
Also, check the engine mounts.
Old Feb 13, 2009 | 03:29 PM
Easy_E1's Avatar
AZ
At an idle put the car in 1st manual mode. With your foot on the brake. Then shift it into second while still stopped. If the noise changes it's the engine mounts. Or one of them . More than likely would be the right side.
Old Feb 13, 2009 | 11:46 PM
laulongfei's Avatar
laulongfei
I am pretty sure that is the engine mount, most likely is the right one just like EASY E1 said. My car have been rattle/squealing over 6 months now, i am just too lazy to get it fix. I know how annoying it is.
Just buy a good used one and replace them, after that go get a engine damper to support it.
Old Feb 14, 2009 | 12:13 PM
lilring's Avatar
Finally a MT
I had that same problem on my 4port AT. For me it ended up being the belts. just replace them. They are pretty cheap
Old Feb 14, 2009 | 12:17 PM
jmc23200's Avatar
When I first got my 04 AT with 44k, it too had a squeal. I checked my belts and they were fine. The noise seemd to be comming from the pulley. A little bit of lube and the sound went away.
Old Feb 16, 2009 | 09:08 AM
JTtheDude's Avatar
Thanks for the input everyone, I've already had the motor mounts changed at one time but I know they suck so I'll check those, I'll also try the belts next. Easy, The squeal doesn't usually last long enough for me to put it in 2nd to see if there's a difference but I've been trying that. As soon as it goes to R or D it chirps. Is it possible to look at the motor mounts and tell if they are bad? Does anyone have a diagram of where exactly they are at?
Old Feb 16, 2009 | 09:40 AM
jmc23200's Avatar
I would have someone change the gears into R or D while you look under the hood to see if you can isolate the sound. Make sure it is someone you trust. Little bros can be more of a pain and break things more often then they actually help lol. Since you do not hear this under load, I do not think its the motor mounts. It is probablly a pulley or a belt squeaking when it hits the 750 rpm area. Normally in N, you idle a little bit higher then when you are in gear. All belts wil eventually squeak. When they do the temporary fix is spraying them with belt dressing or using some lithium grease to lube it. The best fix is replacing the belt.
Old Feb 16, 2009 | 09:59 AM
JTtheDude's Avatar
Yeah I'm going to try and pick up some of that belt spray soon. Is it alright to spray it on the belt before I start the car or does it need to be running when I spray it?
Old Feb 16, 2009 | 10:01 AM
Easy_E1's Avatar
There is a possibility it's the belt idler pulley. Mine makes noise. Awfully hard to diagnose these things over the interwebs.
Old Feb 16, 2009 | 10:02 AM
jmc23200's Avatar
It is difficult to diag over the internet, but you can get a general idea of the issue and give advice. It is possible that it is ANY belt or pulley, but then again, anything is possible. Its ok to spray on the belt while the car is off. I would recommend turning the car on first though. Makes it easier to spray the entire belt while its moving and you can hear it working/not working as you spray if the car is on. Like I said before, just have someone sit in the car, keep their foot on the brake and put it in drive. Then you can isolate the noise and spray away. I usually spray for a few seconds, then wait like 20 seconds to see if it goes away. If not, the repeat. God Luck.
Old Feb 16, 2009 | 03:33 PM
laulongfei's Avatar
laulongfei
I wonder if u have aftermarket intake
Old Feb 16, 2009 | 04:01 PM
JTtheDude's Avatar
I don't it's stock intake.
Old Apr 15, 2010 | 02:16 PM
Cross-F8er's Avatar
I have the same problem too and have been living with it for over a year. the sound seems like it is coming from the right side. the only thing i do to stop the noise is put it in "N" while i am at a stop or a red light. have you figured out the problem?
Old Apr 15, 2010 | 03:07 PM
Easy_E1's Avatar
More than likely a bad engine mount. They go bad easily. They don't last.
They're crap.
Old Apr 15, 2010 | 03:18 PM
Cross-F8er's Avatar
They're crap.
damn, i just got that fixed 30,000 miles ago. engine mount replacement #3 for me i guess. someone should make a more sturdier after market part.
Old Apr 29, 2010 | 04:51 PM
JTtheDude's Avatar
I had my engine replaced in Oct 09, since then no problems. I don't know if it was mounts or what but it happened all the time until it died, maybe it was low compression (cause of engine failure) causing it I don't know. If they don't give new mounts on engine replacement that probably isn't it since it's fine now.
Old Feb 28, 2012 | 01:18 AM
Nopstnz8's Avatar
Bump. Having the same problems on my 04 AT and wondering if anyone has solved this? I'll check my belts and pulleys as well.
The main problem I'm having is that when I'm parked and put my car in drive, I hear this metal on metal rattle that is EXTREMELY annoying and have been trying to figure out how to fix it. I'm also getting vibrations while idling in D with my foot on the brake. I had it looked at by the dealer, and they say the passenger side engine mount is bad, but when I looked at it, there was no obvious sign of it being bad, nor oil leaking. I'm about to replace it anyways hoping to fix the problem, but the metallic rattle is the most annoying. It shakes the whole car from the backend (since the tranny and engine are connected directly). I've noticed though if when I put it in drive and quickly give it a little gas to raise the rpms, I can avoid the metallic rattle and vibrations ever so slightly, which leads me to believe my problem is related to either the engine mount, a tranny mount, or a possible heatshield, but I'm not certain.
Any help would be GREATLY APPRECIATED. Thanks.
Old Mar 10, 2012 | 08:29 AM
RX8 Dyno Dan's Avatar
could it be a rattling catalytic converter?
Old Sep 15, 2012 | 09:23 PM
waterproofone's Avatar
ROTORHEAD
I have auto 05 model too. My mechanic days lots of people complaining and no one can tell what the prob is. He says the new Mazda 6 is doing it too so thinks it is exhaust gasket or something. Mine started about 90k but now 30k later is much worse guess I will be spending some money to try and diagnose. Car sounds cheap idling because of it....so gonna try and solve.
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
D13
Oct 1, 2015 07:55 AM
tommy26Germany
Sep 29, 2015 10:33 AM
