Rp super cat Vs. RB racing pipe
Old Feb 13, 2009 | 09:16 AM
TRU5hot's Avatar
Hey all, I currently have the RB cat back exhaust. I was looking into either gutting out my OEM cat or buying the Rp super cat or the RB racing pipe. Any suggestions or personal experiences. Thanks for your help.
Old Feb 13, 2009 | 09:33 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
don't gut the OEM cat, its under the extended powertrain warranty until 100,000 mi.
Old Feb 13, 2009 | 09:44 AM
rx 8speciale's Avatar
Relax baby!
both will give a check engine cell and pipe IF IT IS resonated will keep the noise down ( my choice )... dont gutt the cat please you will need that for inspection
Old Feb 13, 2009 | 10:08 AM
bose's Avatar
Reginald P. Billingsly
Gutting your cat make you lose power actually. In the most recent issue of Import tuner they did a bunch of dyno pulls with a gutted cat, a high flow cat and a race pipe. Although the power loss was minimal, 3hp less than the high flow cat, 5hp less than the race pipe. But with the cost of a race pipe being fairly inexpensive you might as well do it properly.
Also the race pipe will be much louder that the high flow cat unless you have a good resonator.
Old Feb 13, 2009 | 11:03 AM
jfxp's Avatar
Rotor nut
^ I find it hard to belive that a gutted cat will cause loss of power however I would not gut the cat, you can sell it for the price of a midpipe if you wanted to. I have a midpipe and it is LOUD when your on it. Its all about how much noise you and/or your neighbors can tolerate.
Old Feb 13, 2009 | 11:06 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
Yea IMO, it depends on your cat-back as well. I'm going to gut my SuperCat tomorrow b/c its clogged pretty good. So its cheaper then buying a new pipe and i still get to use the pipe.
After the PA DynoDay i'll post my dyno with my soon-to-be gutted RP SuperCat.
Old Feb 13, 2009 | 11:08 AM
blackenedwings's Avatar
Life begins @ 30 psi
I don't find it hard to believe at all... the shape and size of the cat could definitely cause turbulence which would negate bonus from the lack of backpressure. I wasn't really surprised by that article.
Old Feb 13, 2009 | 04:56 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
my rp supercat failed on me. now i have the racing beat test pipe and still loving it
Old Feb 13, 2009 | 05:09 PM
bose's Avatar
DING DING DING DING DING DING DING. Winner winner chicken dinner. Believe it or not, I don't care it's your car. Just google it, it was proved long before import tuner.
Old Feb 16, 2009 | 03:42 PM
TRU5hot's Avatar
The OEM cat I have was given to me for free I have two and one is gutted. And on the note of losing power, im sure you would lose power on replacing the cat in general. The trick is to tune the fuel ratio so it gains a few ponies. I think im just gonna install the gutted one to see how it is before I buy one. Thanks
Old Feb 16, 2009 | 03:55 PM
bose's Avatar
It's your car, do with it what you will.
Old Feb 16, 2009 | 04:17 PM
baseballgenius80's Avatar
WW8P6OLBJD?
I have a Racing Beat race pipe against a Magnaflow dual exhaust. No resonator on the race pipe of course. I love it!
Old Feb 19, 2009 | 07:35 PM
TRU5hot's Avatar
Just an update. I have put in the gutted out cat and it is running great the MAF on my readings have gone up and the sound is nice not too loud but loud enough with a nice POP in the shifts.
Old Feb 22, 2009 | 10:26 AM
CAT is required in many states.
They can tow you for that.
Also the smell is inbearable unless you get the AP from Mazda Manic.
Old Feb 22, 2009 | 12:37 PM
ronx8's Avatar
zoom zoom!
any difference between rp supercat and rx7store hi flo cat?
i hear rp supercat tends to clog. probably just as true with the rx7 store cat?
Old Feb 22, 2009 | 12:50 PM
L337fpc's Avatar
ლ(ಠ益ಠლ)
The RP SuperCat is made by Rotary Performance @ the rx7.com website.
Old Feb 25, 2009 | 07:16 PM
ZGlide's Avatar
I have a RP supercat for about 3 1/2 years now. How do you know if it's dead?
Old Feb 25, 2009 | 10:58 PM
leerx8bk's Avatar
Can the smell be fixed with any maps or is this something MM has figured out. And can some explain to me how there maps change that gasoline smell coming from the midpipe
Old Feb 28, 2009 | 09:55 PM
Phi's Avatar
Phi
Phi
the AFR would be more lean then the stock maps, but i dont know how much change in smell it would be..
Old Mar 1, 2009 | 12:51 PM
greg985's Avatar
The 337
http://www.youtube.com/watch?v=MkF_fmJpjzc
Old Mar 5, 2009 | 11:22 PM
rapidfire's Avatar
Is the RP mid pipe bolt & gasket kit needed for the install? I have stock header for now(I may go with aftermarket header in the future) and MS cat-back, is there any issue with my setup if I go with this high flow cat? Any thought on this high flow cat on rx7store?
Old Mar 9, 2009 | 10:40 PM
rapidfire's Avatar
Anyone?
Old Mar 10, 2009 | 01:39 AM
Bartste's Avatar
Need a 20B
EU
I just bought a RP supercat AND bolt kit... I think we need it
I hope the RP supercat is good for 2 years...at least...
It comes to complete my exhaust line with a RB rev8 and RB header...
Old Mar 10, 2009 | 03:49 PM
JTtheDude's Avatar
I don't think that the bolt/gasket kit is required but is probably recommended. Depending on if you can get the stock bolts and gasket off without damaging them you could probably reuse the existing stuff. Depending on how old the car is, with the heat the exhaust pipes see day after day it can be extremely hard to get them off without damaging them. I would go ahead and just get it to make things easier for you that way you don't have to worry about being gentle with the current stuff to try and reuse it. A new supercat is almost $400 right? What's another $30 to save you time and trouble?
Old Mar 10, 2009 | 07:34 PM
fisherdn's Avatar
Bartste make sure you post your impressions after installing the pipe because I am considering adding the RB header and RP super cat to my RB cat back, but I'd love to hear what you thought before I do it.
