Will a CAI-Header-HF Cat-exhaust will cause a too lean condition?
Old Feb 11, 2009 | 11:35 AM
Yan's Avatar
Yan
Arrow Will a CAI-Header-HF Cat-exhaust will cause a too lean condition?
... without any ECU tuning?
I plan to run a Racing Beat header, high-flow catted midpipe and HKS single outlet catback, along with a MS CAI.
As the title says, will that cause a too lean mixture without any ECU tuning?
I've done quite a bit of research and I have not found a convenient answer!
Thanx in advance guys!
Old Feb 11, 2009 | 04:19 PM
alienRX8's Avatar
Boosted!!!
I dont think it will seein as rx8's run pig rich from factory
Old Feb 11, 2009 | 04:30 PM
tubingchamp's Avatar
What mawd bug?
I don't think any of those will effect your AFRs except the CAI... The stock ECU can handle the change on that.
Old Feb 11, 2009 | 04:48 PM
alnielsen's Avatar
When the emissions system is running in closed loop, it should adjust to whatever changes you make. In open loop (eg. performance driving), it is running too rich anyway. You should be OK, especially if you stick to premium gas.
Old Feb 11, 2009 | 11:59 PM
Yan's Avatar
Yan
Thanx everyone!
And yeah, I will always put 94 in my 8!
Old Feb 12, 2009 | 12:04 AM
simple answer is no, not a problem.
Old Feb 12, 2009 | 11:47 AM
SRrx-8JC's Avatar
Felix "The Man" Wankel
I have a Midpipe and the HKS single sided exhaust and no cell, and the sound is straight badass. Its a good choice....you will get a lot of grumbling...but to answer your question no you should be fine.
ENJOY!
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Oct 3, 2015 09:51 AM
JCTaylor
Sep 30, 2015 07:31 PM
Tgiolitto100
Sep 29, 2015 10:52 AM
