non functioning meter
Old Feb 6, 2009 | 12:10 PM
drmac's Avatar
Thumbs up non functioning meter
hello to all members.i am a new member.nice site with very useful info for members like me who reside in a country which has very few rx8's and fewer people who understand them.guys i need help.
yesterday after a normal drive i parked my vehicle.after an hour or so i needed go out again.after getting into the car i switched on the ignition but got no display on the speedometer.the only icons its showing are airbag,door light,security and seatbelt liights.the meter does not light up.there is no display for rpm,speed,temp,oil,gears(by the way its an auto 2003)etc.the car is driving normally with no obvious fault.no one over understands what has gone wrong.any help will be appreciated.
thanks in adv.
Old Feb 6, 2009 | 12:16 PM
Renesis07's Avatar
Vtak just kicked in yo!!
thanks in adv.
check the fuses, not sure which one would control that.
Are the guages still functional or is the whole dash inop?
Old Feb 6, 2009 | 12:18 PM
sounds electrical.
I would start checking fuses as REnesis mentioned and also check the wires to the PCM box. Maybe something got loose?
Old Feb 6, 2009 | 12:36 PM
CyberPitz's Avatar
Huge hole is huge
Fuses are always the first place to look when ANYTHING electrical is going on with the car. A blown/lose fuse can cause a world of issues.
Old Feb 6, 2009 | 01:25 PM
Check your battery connections and the charge on the battery.
Old Feb 7, 2009 | 01:50 PM
drmac's Avatar
have checked all the fuses .all are ok.the full meter is nonfunctional.checked all the wiring harnesses.new battery.links are clean.mechanical function is normal.had the meter removed and checked the connection.could not find any fault.
Old Feb 7, 2009 | 02:10 PM
StealthTL's Avatar
Metatron
Did you check the fuses in the footwell?
S
Old Feb 8, 2009 | 01:36 PM
drmac's Avatar
yes.all fuses ok.have found a second hand meter with someone .will be getting it tomorrow.will post progress.thanks
Old Feb 8, 2009 | 02:26 PM
2nd hand ones won't work..they need to be initialized..and the way Mazda has it set up you can't swap in a used module....
You might be able to tell if there is a fault with the original one...but the used dash unit won't work properly
Old Feb 14, 2009 | 12:19 PM
drmac's Avatar
thanks to all who took time to reply.got the alternate meter installed.had to just connect it and nothing else.its working perfectly.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
GK1707
Sep 27, 2015 07:33 PM
