Pre 09 OEM gauge cluster mod???
Old Feb 5, 2009 | 08:34 AM
krijpipudht's Avatar
Hi guys! My name is Tony.
From: San Francisco Bay Area 94542, USA. Earth. Solar System. Milky Way
I believe this tropic has not been discuss here before.
Have anyone try the following?
First mod: self swing.
I pull the room fuse out often when I am installing extra gauges.
I notice OEM gauge cluster does self swing every time I turn the key after pulled the fuse out and put it back.
I think that cutting power to gauge make it does the recalibration by performing self swing. However, you will lost trip counter. (well I don't care much)
Any how to cut the gauge power after the key is out?
Pulling room fuse out is not a good idea since you will loose all cabin light and the clock will reset.
Second mod: color changing gauge face
If driving with windows down, sometime I can't hear the red line beep.
This vid is exactly what I am looking for.
http://www.youtube.com/watch?v=k2K2c3QQgSA
(actually, it would be great if tach turn to yellow at 6500 rpm and red at 7500 )
I'm e-mailing LEDmod.com for more info.
Anyone interesting?
Thanks,
Tony
Old Feb 5, 2009 | 09:01 PM
PSTNLSS's Avatar
The Former PSNTLSS
That's kinda interesting.. If the whole cluster went red on redline or changed color
I mean if you dim the interior lights to begin with and turn on fogs or headlights the gauges go red anyway
Old Feb 5, 2009 | 09:06 PM
lurch519's Avatar
www.evoperform.com
Im sure it could be done, just need to use some type of rpm trigger to trigger the led color change from the dimmer switch. ive already changed the led's in my cluster to blue
Old Feb 5, 2009 | 10:22 PM
What kind of LEDs are used in the gauge cluster?
Is it swappable or it required circuit soldering?
Thanks,
Tony
Old Feb 6, 2009 | 06:19 AM
lurch519's Avatar
www.evoperform.com
plcc-2 leds
requires a very very steady hand and either a specialized soldering iron or crazy soldering skills
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
RX8mzda
Oct 14, 2015 05:12 PM
airlive
Sep 7, 2015 08:32 PM
