turbo fasteners
Old Feb 3, 2009 | 07:49 PM
WingleBeast's Avatar
HAVOC
turbo fasteners
Just recived my used greddy kit and by the looks of it im going to need new fasteners. Nuts are easy enough, but I can't seem to find some studs online
Looks like they are M8 1.25 thread 30mm long. Stainless.
any ideas other than asking greddy kindly?
Old Feb 3, 2009 | 07:53 PM
hakuna matata!
sorry for the obvious.. but auto parts/hardware store?
chickenwafer's Avatar
Nope
www.atpturbo.com
Old Feb 3, 2009 | 07:55 PM
laythor's Avatar
I zoom therefore I am.
http://www.boltdepot.com/
Old Feb 3, 2009 | 07:57 PM
HAVOC
atp doesn't carry stainless. and the only parts/hardware i have around here is walmart....
in related news...
http://www.russellperformance.com/mc...it/turbo.shtml
would that oil return fitting work? or any of ATP fittings for that matter.
Old Feb 3, 2009 | 11:32 PM
Nope
in related news...
You don't need stainless...
That is a banjo bolt you posted. It will not work as an oil drain.
Your kit should have an angled small diameter (5/8") pipe with a slotted 2-bolt flange on one end. That is your oil return pipe. You need to connect a high temp silicone or stainless 5/8" hose to that and to the fitting you screw into your oil drain plug to complete your return setup.
Old Feb 4, 2009 | 12:39 AM
HAVOC
PS im referring to this part not the banjo http://www.russellperformance.com/mc.../697070_lg.jpg
the oil feed line i have is leaky so I would like to run the entire system in some steel braid in AN connectors. SO I was hopeing to find something to replace the metal oil return tube with something more sturdy... with threads.
also found these... im not sure what housing the T618 uses since all i can find is that its a custom build by mitsu...
T67? TD04, TD05, TD06, TD07?
http://cgi.ebay.com/ebaymotors/Mitsu...Q5fAccessories
http://cgi.ebay.com/ebaymotors/Oil-D...Q5fAccessories
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
MolecularConcept
11
Sep 29, 2015 09:21 PM
