rx8strakes footwell lights voltage.
Old Jan 30, 2009 | 11:36 PM
Alexb's Avatar
desperately needs a drop
Hey, so I am wiring up a different circuit than what is originally suggested with the rx8strakes.com footwell lights.
In order to do it I need to know the voltage that they use to make sure I don't send too much power to the lights from a constant source.
Does anyone know the voltage they require to run?
Old Jan 31, 2009 | 01:44 AM
hakuna matata!
12v.. like anything else in the car?
Old Jan 31, 2009 | 01:47 AM
Alexb's Avatar
sweet.
Thanks for your help, you are my savior.
Old Jan 31, 2009 | 01:49 AM
hakuna matata!
also.. though it may probably be unlikely.. make sure the circuit you tap into can handle the additional load (amperage) from the lights.
Old Jan 31, 2009 | 07:58 AM
04RX8man's Avatar
Rotary Powered Countryboy
yes 12v(uh 12v battery) and like al said make sure the amperage will not go over what the circuit fuse is that ur tapping into or u will blow a fuse! constantly
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
