Help, Heater Doesn't work
Old Jan 27, 2009 | 01:42 AM
floyo's Avatar
My Beloved One
Guys, need help here desperately. My Rx8's heater doesn't work.
Any suggestions? Other things check out fine including water temperature, weird
Old Jan 27, 2009 | 01:50 AM
StealthTL's Avatar
Metatron
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-no-heat-repair-heater-control-158200/
No problem, we have a solution!
Involves possible soldering, so you may want to find a friendly tech to do it....
S
Old Jan 27, 2009 | 09:34 AM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
The soldering fix will set you up right and totally fix the problem...
I haven't got around to doing that yet... so in the short term I took the **** off, and just wedged some paper against the **** stem to keep the heater at level 16 in the diagnostic mode.
It may flutter around sometimes, but it is a good short term fix.
I tried taking some pictures of my footwell lights in this pic, but you can sort of see the paper lodge in the **** socket.
Only a good short term fix.
Old Jan 27, 2009 | 09:43 AM
RX8-Frontier's Avatar
I did it on my car. Takes less than an hour of your time to pull the controls out, solder, and put it back together. Works like a charm. On mine, only 2 of the 3 pins were broken solders, but I figured since the thing was out, I'd go ahead and redo all of them. I use a "cold fusion" POS as-seen-on-tv for my small soldering, and it works great, even for someone like me that just plain can't solder very well...
Old Jan 27, 2009 | 07:26 PM
floyo's Avatar
My Beloved One
Thank y'all, StealthTL, Vyndictive, RX8-Frontier, the problem is exactly what you depicted. I have fixed it and the heater works pretty well right now!
Jesus Martinez
44
May 6, 2025 08:09 AM
coolcars44
Nov 29, 2017 05:45 PM
Nisaja
Series II Interior, Audio, and Electronics
Nov 3, 2015 05:30 PM
FirstTimeRX8Girl
Aug 21, 2015 06:51 PM
mazdaverx7
Jul 21, 2015 07:31 PM
