Bad Syncro Maybe?
Old Jan 24, 2009 | 10:27 PM
jhoyt12788's Avatar
VA Bad Syncro Maybe?
Ok, so when it's really cold out and I shift from 1st to 2nd and 2nd to 3rd, I always get this like resistance for a second and a clanking kind of feeling and it goes into gear. I've heard maybe it could be my syncros going? I asked the dealership here and they said its because the tranny fluid needs to warm up and then they should be fine. The problem seems to go away after a couple minutes of driving. If I pull it into neutral and kind of play inbetween neutral and 2nd it get caught inbetween and grinds....what would this be???? I feel like an *** having to call the dealership and take it in all the time and having them tell me they don't think anything is wrong with it....
Old Jan 24, 2009 | 10:43 PM
hakuna matata!
could just be like they said the transmission getting to operating temp - you say that its fine after a couple minutes of driving..
Old Jan 24, 2009 | 10:55 PM
jhoyt12788's Avatar
I mean the car only has 28,000 miles on it. Would it really be that they are just cold though... it seems a little odd for it to clank the way it is because its cold. I dunno.... I just know that my factory warrenty is up in a month or so.
Old Jan 24, 2009 | 11:08 PM
jhoyt12788's Avatar
no I can shift at any rpm, ive noticed it doesnt do it at certain rpms and if i give it a second before i put it into second from first it wont do it.
Old Jan 24, 2009 | 11:22 PM
how cold is cold.
btw, you might add where you are from in your user cp.. it helps.
and really, when the transmission and the car is cold. do not rush the shift..
Old Jan 25, 2009 | 09:26 AM
jhoyt12788's Avatar
cold would be like 20 degrees. and again its only for the first couple minutes until its warmed up.....maybe i need more fluid or to change the fluid? the car has 28k on it.
Old Jan 25, 2009 | 04:07 PM
kersh4w's Avatar
Hit & Run Magnet
its cold enough in va.
first few minutes of driving is a bit clunky. thats how it goes.
Old Jan 25, 2009 | 06:04 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah i think that is somewhat normal when it gets codl I've had my tranny rebuilt and it has done it before and after when it's cold for the first couple shifts then it stops if u hold in the clutch a couple seconds it does not grind(at least for me)
Old Jan 25, 2009 | 07:16 PM
jhoyt12788's Avatar
thanks guys, it really only seem to be those 2 gears that have any problem though. i would hate for anything to happen to my 8. I love this car. I drive it sometimes just to drive!
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
duworm
Oct 1, 2015 04:57 PM
Tgiolitto100
Sep 29, 2015 10:52 AM
pjwermuth
Sep 28, 2015 11:36 PM
