Car doesnt want to start help
Old Jan 24, 2009 | 09:44 PM
pbmlewis's Avatar
It sounds like it wants to turn over but wont...i replace filter for intake,spark plugs and wires, changed oil and filter, and air sensor please help with ideas... ask any ?s you need
Old Jan 24, 2009 | 09:48 PM
AAChaoshand's Avatar
Rotary Powered
have you checked your battery? What exactly is the sound being made? A full crank, slow and weak crank? Need more info bro.
Old Jan 24, 2009 | 10:34 PM
pbmlewis's Avatar
yea battery is fine and so are the connections... cleaned them to be safe... as far as i know and it cranks strong like it wants to start...
Old Jan 24, 2009 | 10:42 PM
hakuna matata!
coils?
Old Jan 25, 2009 | 01:46 AM
pbmlewis's Avatar
really...they were saying it might be the fuel filter or i flooded it...
Old Jan 25, 2009 | 01:47 AM
pbmlewis's Avatar
and by they i mean people i know...not mechanics so help a brother out still lol
Old Jan 25, 2009 | 01:53 AM
hakuna matata!
oh that's right.. so long since I read a post of someone flooding their car.. so that is what it could be.. try the process in the owner's manual for deflooding.
Old Jan 25, 2009 | 01:58 AM
pbmlewis's Avatar
i will but anymore ideas people i can try tom?
Old Jan 25, 2009 | 11:18 AM
Rotary Powered
well, have you tried getting it pushed and starting it? Sounds stupid but sometimes it needs it. Flooded is a great possibility though.
Old Jan 25, 2009 | 11:22 AM
invasion08's Avatar
did the car run before you changed the plugs and wires?
Old Jan 25, 2009 | 12:37 PM
pbmlewis's Avatar
yea but it was very bogged down and would cut off but after i fixed them it was fine... that was this last summer/fall...I didnt drive it much when I figured out something was wrong... my 8 hates me
Old Jan 25, 2009 | 12:39 PM
pbmlewis's Avatar
if it didnt want to start a few times before, like took a few seconds could it really be flooded...i thought that happened all at once...I really dont wanna deflood unless its nec.
Old Jan 25, 2009 | 12:45 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yes...............de-flood it!
Make sure your wires are correct and on tight.
Did they snap on? If not push a little harder.
Old Jan 25, 2009 | 01:29 PM
04RX8man's Avatar
Rotary Powered Countryboy
flooded....
Old Jan 25, 2009 | 02:07 PM
Rotary Powered
dum dum dum! j/k seriously though, I think I had a few close calls on that after it didn't want to crank, got it after 5 or 6 seconds though.
Old Jan 25, 2009 | 02:31 PM
lepichichi's Avatar
I LuV mY Rotary....
flooded maybe???
Old Jan 25, 2009 | 05:38 PM
04RX8man's Avatar
today was the first time i shut if off cold as hell back it out of a parking spot maybe started 10 seconds and it didnt' flood but was running rich as hell i'll tell u that !
Old Jan 25, 2009 | 07:08 PM
Mazurfer's Avatar
^.............Almost!
Old Jan 25, 2009 | 07:10 PM
hakuna matata!
Just 2 days ago I accidentally turned the car off when it was 9f out.. windchill was below zero. The water temp was at 30f when it went off.
Car started up in less than 2 cranks.
Old Jan 28, 2009 | 03:16 PM
jmc23200's Avatar
Make sure you put the leading plugs and trailing plugs in the right holes. Also, like stated above, make sure the wires are on the correct spark plug/coil. If it's a MT, you may need to have someone give you a tow around the block to get it started, a simple push may not work since it's flooded. I say its flooded since you tried to start it multiple times and it didnt start. There are multiple threads on deflooding your engine.
Make sure you have gas in the tank. If you have gas in the tank, did your GF/mom pump it for you? Maybe the filled it with diesel
Old Jan 28, 2009 | 04:58 PM
Rotary Powered
or kerosene!
dbarber
Jul 25, 2015 01:34 PM
T_Mags
Jul 24, 2015 11:29 AM
Bamaham
Jul 23, 2015 08:08 AM
thedragonrotar
Jul 22, 2015 08:46 PM
Kangarhew
Jul 18, 2015 08:27 PM
