Help! Wiring "ON" - wire to circuit that will not be turned off when key is turned
Old Jan 23, 2009 | 05:41 AM
krijpipudht's Avatar
Hi guys! My name is Tony.
From: San Francisco Bay Area 94542, USA. Earth. Solar System. Milky Way
My gauges require 5 wires to power up and working properly.
Batt + : connect to always-on 12V.
Ground
On : wire to ciruit that will not be turned off when engine is cranking"
ACC : wire to ciruit that turned off when engine is cranking
Small Lamp: for night time dimming
Problem is
I can't find any where to tap "On - wire to circuit that will not be turned off when engine is cranking" in the kick panel fuse box.
according to StealthTL (https://www.rx8club.com/newreply.php...eply&p=2830785)
Originally Posted by StealthTL
The problem is that anything 'switched' will go thru a relay, and relays drop out during cranking.
I don't think you'll find a steady signal during cranking....
S
Seems like there is no such circuit in 8 that won't cut while engine is cranking.
8 only has always-on and ACC, which will be cut during cranking.
Any one know where to tap such circuit?
If not any mod would do? (ie. bypassing relay from unused circuit to feed "On" requirement. My 8 does not have Nav, power seat, or Bose)
If not thing work. I guess I have to get new gauges with different power requirement.
Thanks,
Tony
Extra note:
My gauges have opening and closing ceremony. They need both ON when engine is cranking and ACC to determine if engine have been start or not.
I tried to hook On-orange wire to constant 12v., everything works except after ending ceremony, gauges stay in Stand-by mode and won't turn off, even after key is removed.
(Needle blinking, waiting for engine start to perform opening ceremony and fully function)
Old Jan 24, 2009 | 01:32 PM
cajunrx8's Avatar
Rotary Crawfish
What kind of gauges are you using? also can you scan a copy of the wiring directions or schematics, I would like to see how they are wired.
Old Jan 24, 2009 | 07:04 PM
jskup1's Avatar
The Chief
I used a wire going into the TPMS module under the center dash panel next to the passenger airbag.
Old Jan 24, 2009 | 07:20 PM
Manual.
I am looking to tap the orange wire in highlighted sections.
Thanks,
Tony
Attached Thumbnails Help! Wiring "ON" - wire to circuit that will not be turned off when key is turned-swoosh-wiring-01.gif   Help! Wiring "ON" - wire to circuit that will not be turned off when key is turned-swoosh-wiring-02.gif
Old Jan 24, 2009 | 07:28 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
I'm looking
Old Jan 24, 2009 | 07:32 PM
Thanks a lot.
Lets see if I can find that.
Old Jan 24, 2009 | 08:27 PM
Is it from this area?
pix from https://www.rx8club.com/showpost.php...&postcount=569
Old Jan 25, 2009 | 10:13 AM
jskup1's Avatar
The Chief
That's it. I forget which wire it was though. Should be pretty easy to figure out.
Old Jan 25, 2009 | 10:59 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
There are several Fuse's that you can tap that are Hot while the car is off.
Use the ones that are located in your cabin fuse box (drivers side, by the dead pedal). I have a 20A and a 30A tapped for my AFR gauge. Works like a charm. But then again I wried my gauge to a rocker switch as well.
Old Jan 25, 2009 | 03:30 PM
jskup1's Avatar
The Chief
He's not looking for a "constant" 12V source. He needs 12V when the ignition is in the acc and on position but will not temporarily turn off while cranking the engine.
Old Jan 25, 2009 | 04:18 PM
Blackout04RX's Avatar
Need for Speed Satisfied
why not just tap into a direct battery connection, and add in a switch? so you can control when it is engaged?
Old Jan 25, 2009 | 04:28 PM
Mazurfer's Avatar
That was my thought. I'm not sure why this hasn't been the considered approach?
Old Jan 25, 2009 | 05:40 PM
paulmasoner's Avatar
Asshole for hire
i may be totally out of my mind, but i've seen this question about 10 times here. there is an answer, and IIRC the room fuse/circuit is only powered in the ACC/ON position and does not loose power during cranking...
this would be easy to check... get in your car at night, leave the door open so the interior/door lights are on. start the car and see if the lights cut out.
even if i am mistaken, it CANT be that hard... every ricer kid in the world has figured it out so....
Old Jan 25, 2009 | 08:09 PM
"Room" fuse circuit is constant on, even key is out and car is off.
I am not looking for that.
Thanks for your suggestion.
Oh and yes, I'm ricer.
I have AP work just like those gauges that I'm installing.
Gauges just look nicer.
Old Jan 25, 2009 | 08:21 PM
If I have to swish it on and off every time, I would rather get new set of gauges.
It will be ok for couple time and then I might just get to lazy to turn it on.
Thanks anyway.
RevMeHarder
Jun 1, 2026 02:30 PM
mattymack
Sep 6, 2015 10:33 PM
Emmanyei
Sep 4, 2015 11:38 PM
