I got a big problem or maybe not , help !
Old Jan 22, 2009 | 12:03 PM
mar10's Avatar
Every time i pull the dip stick out its covered with white residue from top to bottom , the oil itself is clean so i dont think its a headgasket and the coolant level does not change nor the temp. go up . Is there some kind of a breather somewhere that might b clogged or pcv valve ?
Old Jan 22, 2009 | 12:04 PM
dozer's Avatar
on his 3rd rx8
headgasket?
Old Jan 22, 2009 | 12:10 PM
subatomicparticle's Avatar
Can I get a Baum!!
I had this same problem took it to the dealership and the mazda tech said that it was pretty normal and all they did was add a sleeve around the dipstick to keep the white stuff off. Which this happened like 3 years ago roughly and I haven't had any problems but it still shows up once in a while. They said it could be from not letting the engine to full operating temps before shutting it off.
Old Jan 22, 2009 | 12:11 PM
TheWulf's Avatar
My 8 looks like a Smurf
None of you guys have even looked at the Tech forum? Really?
Old Jan 22, 2009 | 12:13 PM
tubingchamp's Avatar
What mawd bug?
A good habit to have is to NOT shut the engine down cold. Let it warm up to the full operating temp.
But the white milky substance is pretty normal. I've had it once or twice in the year I've owned my car.
Silver06's Avatar
Zoom Zoom....
Oh No!!!
You've spun a camshaft bearing!!!!
Seriously,
Please search. This thread is a sticky: in the Issues & Problems section: https://www.rx8club.com/series-i-trouble-shooting-95/strange-gunk-oil-dipstick-info-questions-49652/
Old Jan 22, 2009 | 12:52 PM
PaQuiN's Avatar
Ballin'
Well he only has one post...give the guy a break. Ya, it's completely normal. Some people get the sleeve to stop this issue but it does absolutely nothing but keep that white stuff away. It won't affect economy, longevity, performance, nada...
Old Jan 22, 2009 | 01:30 PM
Thumper3322's Avatar
Yup no research In short it's normal and happens in the winter below a certain temp. There is tons of stuff on it, just ignore and move on with more important matters like....mmm turbo!!!
Old Jan 22, 2009 | 03:26 PM
REV-illusions's Avatar
rotary ninja
good on you for remembering to check the oil at the very least..
Anyways... as most people have pointed it.. it's normal.. it's just condensation from when the engine cools down mixed with the oil and then you get that sludge. No need to worry...
Old Jan 23, 2009 | 09:31 AM
mar10's Avatar
I am new to the rotary family and love in ,thanx a lot guys for the response and not being too hard on a newbe for not researching it , but jsut got a little worried , i have had problems with a head gasket before and that was the first thing that would show on the dipstick .
Old Jan 23, 2009 | 12:27 PM
PaQuiN's Avatar
Ballin'
Luckily your car does not have a head gasket...well, maybe not lucky. You have what is known as an Apex seal. The seal is the weak point of the engine IMO. There is no cylinder head on the Renesis becuase well, there is no cylinders...two compartments. I guess you could call the Apex a compartment gasket....
Old Jan 23, 2009 | 12:34 PM
paulmasoner's Avatar
Asshole for hire
side seals.... 13B-REW apex's are considered the weak link. 13B-MSP side seals see more stress
JimmyBlack
273
Feb 10, 2020 10:23 PM
LB2739
Jul 9, 2019 02:25 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
juicemantwon
Sep 26, 2015 12:30 PM
