Brown-ish "goo" on oil dipstick.
Old Jan 21, 2009 | 03:47 PM
nc.wiles's Avatar
I just checked the oil in my '04 8 GT. There is a brown-ish "goo" all the way up and down the dip stick. This is the 2nd time this has happened. My dad, who manages a shop said it could be condensation on the dip stick. It was freezing the first time, today was about 45 degrees. Has anyone else had a problem with this?
Thanks.
deadphoenix52's Avatar
meh.
normal
Old Jan 21, 2009 | 03:49 PM
09Factor's Avatar
Original Turbo 'd Auto !!
Yep thats normal for condensing environments.
Old Jan 21, 2009 | 03:51 PM
04RX8man's Avatar
Rotary Powered Countryboy
In Before The Lock!!!
Old Jan 21, 2009 | 03:57 PM
nc.wiles's Avatar
Cool. Thanks.
Old Jan 22, 2009 | 12:48 AM
Nubo's Avatar
Lubricious
Check the Stickies in Issues and Problems.
Old Jan 22, 2009 | 12:58 AM
mrinno's Avatar
Again ? Wasnt there one of this last week?
Old Jan 22, 2009 | 12:59 AM
laythor's Avatar
I zoom therefore I am.
it's that time of year... i'm just happy to see so many new owners are doing the right thing and checking their oil.
but yeah.. please search.
Old Jan 22, 2009 | 08:11 AM
mazdaverx7's Avatar
RX-Heaven
there's a tsb on this as its a normal occurance. the tsb replaces and adds some hoses for the pcv setup.
http://www.finishlineperformance.com...50-06-1664.pdf
Old Jan 22, 2009 | 08:25 AM
dillsrotary's Avatar
jersey fresh
I would go see a doctor immediately and tell all your previous sex partners.
Old Jan 22, 2009 | 09:56 AM
Another idiot
Old Jan 22, 2009 | 01:32 PM
toddiesel's Avatar
Thanks.
I just bought my 8 two weeks ago Saturday. I went to check my oil level and I noticed something similar to what you're talking about. I don't know that I would describe mine as brownish-goo though. Mine was almost milky as if I had a leaking head gasket. I actually haven't seen this first hand, I just know that's what to look for on a standard piston engine. It has been pretty cold here as well, below freezing some days and some days not. When I checked it, it was about 50 degrees. The part of the dip stick that was actually covered with oil looked pure but the... and I hate to use this term... "milky" film was in spots along the entire length of the dip stick. Does this seem like the same thing?
Old Jan 22, 2009 | 01:38 PM
Greenblurr93's Avatar
Sotally Tober
Thanks.
Brownish goo on the dipstick?? Id say you put it in the wrong hole...
Now all kidding aside... yes it normal.. same answer for the poster with the milky substance
Old Jan 22, 2009 | 01:39 PM
Silver06's Avatar
Zoom Zoom....
^TODDIESEL Yes it is.
Condensation forms in cold temps when the engine / oil cools. Short-duration driving cycles does not allow the water to 'boil off' through the PCV system.
If you have an '04 or '05, the PCV hose routing was later changed to prevent this sticky goo from then depositing in the intake & MAF - now going to the lower intake manifold. For early year cars, get the hose routing changed (see TSB above) or get a catch-can.
Again, don't worry about it. Make every few drives a long drive to get rid of the condensation - and have some fun!
Old Jan 22, 2009 | 01:55 PM
zoom44's Avatar
read the stickies and the "winter thread" i link to in my sig
thread closed
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
