RedLine MT-90 Trans fluid - hard to go into gear
Old Jan 20, 2009 | 07:14 PM
PBlue's Avatar
Dial P for Phantom
I swapped out my trans fluid for Redline MT-90 last month. One i took the car down and did a little test drive, it was pretty smooth shifting. I drove around for a week with it performing like normal. I went out of town for 2 weeks. Immediately upon return i noticed it was somewhat difficult to go into 1st. It wouldnt go in, and even holding it against the synchros it wouldnt slide in after the 1 sec delay like it used to. Now i have been testing more carefully and it takes a lot more force to downshift into 2nd even only going 20-30mph. It used to be smooth, now its like im fighting with it.
When i changed fluids i did the normal drain, open top, open bottom, let drain for a while, close bottom, new crush washer, put in 2 quarts of Redline mt90, close top w. new crush washer. Ive checked and dont think any is leaking. I did spill some of the old stuff in the parking lot where i did the change, and apparently it eats away asphalt... and i got it all over my hands at the time but i would have noticed it if it were leaking where my car is always parked.
So... Anyone ever heard of this?
Old Jan 20, 2009 | 07:21 PM
04RX8man's Avatar
Rotary Powered Countryboy
you are sure it was full?? does it get better after you drive and the tranny fluid warms up?
Old Jan 20, 2009 | 07:31 PM
am22's Avatar
i did the same over summer but mine took 3 quarts.
Old Jan 20, 2009 | 07:38 PM
LionZoo's Avatar
road warrior
Is this when warmed up or only when cold?
Old Jan 20, 2009 | 07:43 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
try to drive it more like another 2 weeks or so and see if it gets smoother and if not i think something is up with your synchros.
Old Jan 20, 2009 | 08:20 PM
Jon316G's Avatar
Grasshopper
MT capacity oil is 1.75L (1.8qt)
Though when I did mine, I managed to get a full 2qts (it was RIGHT at the top of the fill hole).
Old Jan 20, 2009 | 09:10 PM
PBlue's Avatar
Dial P for Phantom
it kind of gets a little easier as it warms up, but still not like stock was.
Old Jan 21, 2009 | 12:19 AM
pull the fill plug, make sure it is not over filled. and it is..
let it drain to the proper level. and then get back to us.
Old Jan 21, 2009 | 05:08 PM
kersh4w's Avatar
Hit & Run Magnet
make sure the car is not jacked up when you let it drain to the proper level...
Old Jan 22, 2009 | 05:45 AM
PBlue's Avatar
Dial P for Phantom
how can i get to the plug if the car isn't jacked up?
also, i asked the question to redline and this was the response i got:
"Paul, thanks for the note and sorry for your problem. We take something like this very seriously and try to help where we can.
We've double-checked all of Mazda's specifications for that transmission, and it asks for a 75W90 GL-4 gear oil. Are you certain that you used MT-90 and not MTL? MT-90 is the correct recommendation for that transmission.
Some transmissions can be very finicky. As you know, MT-90 has a great reputation for a reason--it helps nearly every box in which it is used due to balance friction (rather than being too slippery) and very stable viscosity (to help with both cold and hot shifting). Most of the time, when any gear oil is changed and it you encounter a problem like this, a syncro was already damaged before the oil was changed and a difference in viscosity and friction exposed it.
A good way to figure that out is obviously to put the stock oil back in it and see if it goes back to normal. Autocross and track days are hard on the tranmission. They do get damaged beyond what they oil can mask. It sounds corny, but this box may have developed a bit of its own personality due to hard use and it may just like the stock oil.
I will look around a bit and see if others have had luck with any specific product when a syncro gets sticky like this. I will also contact my friends on the engineering staff at Mazda (they use a lot of our stuff) to see if they have any ideas.
Hope that helps, Cameron"
Old Jan 22, 2009 | 06:28 AM
Bastage's Avatar
DEVILMAN
Was the car level, and did you fill it until the stuff was leaking out of the fill hole? If you used MT 90 you used the right stuff, that's what I have, and I actually had a bit of improvement in shifting after I did the swap.
Old Jan 22, 2009 | 01:02 PM
LionZoo's Avatar
road warrior
Yup, just lower the car to it's normal position while leaving the plug out. If you're on a level surface, then excess should drain out.
Old Jan 22, 2009 | 03:34 PM
kersh4w's Avatar
Hit & Run Magnet
^ right.
jack the car up,
take a wrench to the plug,
put a fluid catcher below the tranny,
jack the car back down.
Brettus
Series I Engine Tuning Forum
46
Apr 19, 2024 06:28 AM
WranglerFan
May 31, 2022 07:51 AM
DVerdeyen
Sep 13, 2015 11:19 AM
GARCIAC951
Sep 10, 2015 07:17 PM
