Feedback? Tried Everything?!
Old Jan 13, 2009 | 08:08 PM
Zepo.'s Avatar
Redlined Rotary = Sex
CA Feedback? Tried Everything?!
Well i'm having some bad feedback issues. At first i thought it was a grounding issue so i ran a 6 gauge wire up to a grounding bolt to in the engine bay. Didn't help so i connected it directly to the battery. That made it worse so i put it back to the grounding bolt. Pissed me off because i did that for nothing . So then i proceeded to try disconnecting the RCA's from the LOC. That made it stop so i threw in a ground loop isolator. Made it sound like i was in a fishbowel so i took it out. What can i possible do to make this go away because it's starting to drive me crazy
Old Jan 13, 2009 | 09:38 PM
WikkedOne's Avatar
Deals on wheels
Do you have everything in your car using the same ground? - the amps and LOC and everything should have the same ground..
and it may be your LOC itself - cheapy ones seem to crave some feedback.
another thing you may try is to turn the pre amp from the LOC up and turn the amps down - that way they aren't amplifying the noise as much
and what components are you using? give us some names and models and how you have it hooked up.. you have a problem somewhere and we will start naming stuff till we get it right
Old Jan 13, 2009 | 09:55 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Fishbowel...is that similar to a wet fart?
Sorry...couldn't resist.
Old Jan 13, 2009 | 10:11 PM
Zepo.'s Avatar
Yep and it gets worse when you accelerate lol
But on a more serious note when i was installing the LOC i was told not to ground it. Was this a mistake?
Old Jan 14, 2009 | 11:50 PM
Quinchu's Avatar
Switcher
The LOC really doesn't matter if its grounded or not. Although its worth a shot to see if that could be it.
What do you have in the vehicle, is it a 4 channel amp pushing speakers, or a 2 channel amp running subs? If its subs then it sounds like the grounds aren't good enough, did you make sure you cleared the area of paint before using it as a ground? If its a 4 channel amp running speakers then you need to run your power and RCA's on opposite sides of the vehicle and then that may clean up your sound issues.
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
Dokuji
Nov 1, 2016 02:51 PM
RX8mzda
Oct 14, 2015 05:12 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
T_Mags
Jul 24, 2015 11:29 AM
