TPMS help
Old Jan 10, 2009 | 08:50 AM
Adino's Avatar
CrossFit Eternal
TPMS help
I have noticed on colder days (35 and below) my TPMS will kick on...sometimes. It's very inconsistent and usually after the car warms up and I put around 10 miles on it the warning light kicks off. Any ideas?
Tire pressure seems fine, stock wheels. Any help is appreciated.
Old Jan 10, 2009 | 09:01 AM
04RX8man's Avatar
Rotary Powered Countryboy
When it's cold your pressure in ur tires gets less becasue the molecules are tight together after driving the tires warm up and heat up the molecules and they expand to put more pressure! What is ur pressure ur runningnow!.
I ran into this same problem and i upped my pressure like 2psi and never ran into this problem i'm at like 35 now if ur 32 psi put it up some and should never run into any problems!
Old Jan 10, 2009 | 09:35 AM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
Heat from driving a few minutes expands the air, raising the pressure back up above the threshold to turn the light off.
You should still add some air because of the cold days. in my opinion.
Old Jan 10, 2009 | 11:45 AM
Adino's Avatar
CrossFit Eternal
I'll give it a shot today, thanks guys.
Old Jan 10, 2009 | 12:14 PM
ShellDude's Avatar
weeeeeeeeee
You want to have 32psi at the coldest possible ambient temperature. I'm actually running closer to the 34psi right now with it being between 20-40 degrees outside.
Old Jan 10, 2009 | 01:59 PM
invasion08's Avatar
Remember every 10 degree drop in temp you lose 1psi.
Old Jan 10, 2009 | 09:52 PM
on the cold side the tpms will kick on at 26 psi..
cold will set it off.. it it goes off when you drive it, your really need to check the pressure..
Warrior777
Jun 24, 2019 04:47 PM
michaelsk8er
Nov 9, 2015 07:06 AM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
ShadowDragon78
Aug 21, 2015 03:29 PM
rx8cited
25
Feb 14, 2004 06:11 AM
