Got the LED FOOTWELL set but..
Old Jan 9, 2009 | 12:10 AM
2fast~'s Avatar
The instructions that came with it shows how to tap into the map light/door lights set. I need help on figuring out the wiring to hook it up to the dash/parking lights, so it can be on all the time at night..
Any help on this issue is appreciated, thanks. :D
Old Jan 9, 2009 | 12:40 AM
Blackout04RX's Avatar
Need for Speed Satisfied
just tap into an accesory light, and put in a switch. thats what i did with any and all lighting i did aftermarket. works wonderfully.
Old Jan 9, 2009 | 11:29 AM
Rickjames25's Avatar
JDM r6_rx8
splice it into your light inside your glovebox. it uses the same switch that your headlights use. so as long as you turn on your headlights or just the marker lights the leds will be on.
Old Jan 9, 2009 | 02:47 PM
nuke0907's Avatar
Never Blend In
why would you want it like that? you might want to check with your state about legality issues. i'd recommend doing what was suggested earlier and installing a dedicated switch for the footwells.
hufflepuff
May 30, 2016 10:45 AM
RX8mzda
Oct 14, 2015 05:12 PM
duworm
Oct 1, 2015 04:57 PM
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
