WTF is wrong with the Heater!!!!
Hey guys I need some help I have a 2005 Rx8 and it just got cold here in kentucky about a month ago and at first my heater worked fine now all it does is blow cold air but every now and then it will work for maybe 15mins and then will start blowing cold air????? any suggestion on what could be the problem and how much will it cost?
https://www.rx8club.com/showthread.p...ght=heater+fix
^ shows whats wrong.
Your car can display the heater level on a scale of 0-16 (0=cold 16=hot)
Your car will display this by hold the power button and the seek up button at the same time.
You can follow the fix above, or, take the temp control **** off and (very ghetto) jam some paper or something else in there to get heat until you feel like fixing it.
I just fixed this on my '04 last weekend. Took the circuit board out & soldered. If you're in/around Louisville, and too afraid to do it, come by sometime and we can take care of it.
Dealer will charge a fortune, as the circuit board is +/- $300 plus labor...
Want to take a trip up to the Football Hall of Fame? (and while you're here fix mine?)
how much would you charge me to do this
Learners_Permit
Sep 27, 2015 07:38 PM
