with slight input of gas pedal, RPM drops..
Old Jan 5, 2009 | 04:01 AM
brokenhelmet's Avatar
Hi, I'm after I have changed all my coils, plugs and wires, everything, I'm not sure if this is problem with vacuum or what, but after engine completely warmed up, it seems I can see this problem easily at idling, if I give a real slight input to gas pedal, RPM drops suddenly to 600~500s and recover to 800 in a short moment.....
no engine check light tho.... is it because car runs too rich or what?...
or because of throttle body?.. or fuelpump ?... again?......
argh..... help........
Old Jan 5, 2009 | 04:29 AM
DOMINION's Avatar
I don't buy Kool-Aid
Do you have a AT? or MT? also did you replace everything with oem stuff?
I would check your plugs. On might not be on all the way. Dont follow whats on the spark plug box when installing. Replace one at a time and check the DIY for pix of where the T and L plugs are.
Old Jan 5, 2009 | 04:31 AM
yup... it's '05 6mt... and.... yup.. have replaced and checked all Trailing and Leading plugs wires and coils...
Old Jan 5, 2009 | 06:46 AM
ZumnRx8's Avatar
RX8 & RX7 owner
Maybe your throttle cable is loose? LMAO, j/k good luck i would get that fixed its def not normal.
Old Jan 5, 2009 | 07:47 AM
DeViLbOi's Avatar
The devil made me do it
Just a guess but if your car was running rich to compensate for your bad plugs it may take a little bit for it to relearn trim to come back down.
Old Jan 5, 2009 | 12:23 PM
cjkim's Avatar
^noob
give it a few cycles.
i'm guessing you unplugged the battery?
Old Jan 6, 2009 | 05:57 AM
DOMINION's Avatar
You can reset the ecu. Unlugg your battery pump the gas peddle till you see the oil gauge go up to the center then back down. See if that works if not i'm going to say it could be your gas filter??? IDK...
Old Jan 10, 2009 | 08:53 AM
04RX8man's Avatar
Rotary Powered Countryboy
Zum i'm hoping u know that it's fly-by-wire on the throttle! haha I'm guess that was a tad of sarcasm!
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
DVerdeyen
Sep 13, 2015 11:19 AM
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
