Weird noise
Old Jan 1, 2009 | 12:04 PM
minnysung's Avatar
Weird noise
Recently I changed my ignition coils, spark plugs, and wires. My mechanic told me that the front trailing spark plug hole was warped a little bit and the plug wouldn't go all the way in, but he said he got it fixed. So I checked myself and sure enough, the plug is all the way in straight and tight. As I was driving back home, it felt like my car was revitalized except there is a small rattling/gurgling noise whenever I accelerate. When I let go of the gas pedal, the noise stops. I've drove it for about 200 miles now, and there isn't a problem. I just wanted to know if anyone knew if this is going to effect my car negatively in the long run.
Also during the coil,plug,wire change I changed my engine oil to 5W30 RP oil and replaced the clutch wire to Racing Beat's stainless steel.
The car is 2004 6-MT with about 56,000 miles.
Old Jan 3, 2009 | 12:07 AM
mazdaverx7's Avatar
RX-Heaven
warped plug hole huh?? never seen one warp and i've got 10 years of the rotary ownership and mechanicals under my belt. at any rate, have you narrowed the rattling down to a particular area. does it come and go as the engine rpm's change? the first thought that comes to mind for me would be a loose catylitic converter heat shield.
Old Jan 3, 2009 | 12:11 AM
Cross threaded plug Kick Mechanic in ***......hard
Old Jan 3, 2009 | 07:52 AM
raleighRX8's Avatar
hello, is this thing on?
I have a similar noise when I accelerate, but only aboue 4700 rpm's only when the secondaries open/ If I let up off the accelerator it stops/ seems to be only under a load/ weird
Old Jan 3, 2009 | 08:17 AM
am22's Avatar
Ya I’ve had the same problem too and someone on told me it might be detonations.
Old Jan 3, 2009 | 09:17 AM
raleighRX8's Avatar
I am going to take mine to the dealer today/ I will let you know what happens!
Old Jan 3, 2009 | 09:44 AM
raleighRX8's Avatar
Of course! I went to take my car to the dealer and it isn't making any abnormal noise! Thats how it goes, it will probably do it all week and when I have time to take it in it won't do it again!
Old Jan 3, 2009 | 10:26 AM
mazdaverx7's Avatar
RX-Heaven
^^thats always how it works..my brakes have been squealing since i bought the car..new pads all around..tsb says shims need to be applied to pads and grease applicable points. stopped squealing on the way to the dealer..as soon as i left the dealer, wouldnt you know it, started squealing again.
Old Jan 4, 2009 | 05:18 PM
04RX8man's Avatar
Rotary Powered Countryboy
does it sound like marbles in a can? That may be detonation. what octane rating of fuel are you using? also what is ur location
Old Nov 16, 2010 | 08:29 AM
xAgyex's Avatar
Dam did anyone figure out this problem? My girl is having the same problem in her 8. The noise comes from the Gauge Cluster...as I accelerate sounds like sparks...or marbles hitting each other a lot...chatter.
RevMeHarder
Jun 1, 2026 02:30 PM
Quiggs321
Sep 30, 2015 05:34 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
