cajunrx8
01-01-2009, 11:07 AM
After seeing this brought up in some other posts, I wanted to throw this out to the masses. Feel free to add anything you want.
All of this can be had at a Sears, Harbor Freight, Big Lots, ect...
The point is for most home jobs a Snap-on or Mac set is overkill.
Buy what your budget allows and go with a decent name brand.
1. a set of metric 3/8 drive shallow and deep sockets 10mm to 19mm
2. a set of metric 1/2 drive sockets 10mm to 24mm or bigger if comes in a set.
Really nothing in a normal driveway repair should go bigger than 24mm ???
3. 3/8 drive extensions 3" long up to 24" long, get some wobble tips also.
4. 1/2 drive ext. 3" to 12" long.
5. a good set of screwdrivers, both flat blade and phillups in various lengths and
sizes.
DON'T go cheap on the Phillups screwdrivers!!!! Trust me on this!!
6. 3/8 and 1/2 inch drive ratchets, I suggest getting a long handled 1/2 drive also
for lug nuts and such, transmission mounting bolts.
7. a set of cheap 1/4 drive socket/driver bits kit and a couple extensions.
8. a set of open/box wrenches 8mm to 24mm, get a decent brand here, Stanley
is not to bad.
9. a set of allen wrenches and or allen sockets, 4mm to 10mm should be good.
10. good cutting pliers, crimping pliers, real Vise Grips pliers.
11. Volt/ohm meter, digital is prefered, 12V test light, various different crimp
terminals and some shrink tubing for wire connections.
12. a nice tool box to put it all in.
sizes.
is not to bad.
