Fuse block addition
Old Dec 26, 2008 | 12:32 PM
BBQdDude's Avatar
BBQ Smoker Addict
Fuse block addition
Hi,
I am thinking about adding something electrical under the hood. Instead of running off of the battery I was wondering how I would add a fuse to the fuse block and use that? I searched but did not find anything on here covering this.
Thank you,
Brian
Old Dec 26, 2008 | 02:10 PM
It can be done if you have the right connectors...but it is likely easier to buy a small 4 gang fuse block and add it somewhere instead.
If you have the right connectors.....put a pigtail on it...and connect to the hot side power...and then connect the other side to the accessory. You need to be careful if they are high output accessories though...to much load and it will blow the main fuse...
cliffkemp
Dec 24, 2024 10:48 AM
ShellDude
Oct 1, 2015 09:55 PM
Evan Gray
Sep 26, 2015 12:30 PM
