Another Octane Question
Old Dec 26, 2008 | 06:15 AM
HUSSAIN's Avatar
Rx8 Owner Manual for JDM or another Octane Question
I have a JDM rx8 and i beleive that downunder you have the same model.
Here where i live the octane is rated in Ron and there are two types available 88 Ron and 97 Ron. I do not have a manual for JDM so need your help.
What is the RON recommendation for rx8. I beleive that for usa it is 91 octane but their octane number is different than ron as it is ron+mon/2.
If somebody can give me australian rx8 manual then that would be great.
Old Dec 26, 2008 | 04:55 PM
Revolver's Avatar
Shootin' from the hip
I'm not sure if the rating is the same there but here we use 95 RON or better (e.g. 98 RON).
So to be on the safe side, I'd use the 97 if I were you.
Old Dec 26, 2008 | 06:36 PM
UserrName's Avatar
RX-8Buddy
95 RON is equivalent to about 90-91 octane. RON is about 4-5 points higher than the equivalent octane rating used in the U.S. and some other countries. 97 RON it is.
Old Dec 26, 2008 | 07:21 PM
97
Old Dec 26, 2008 | 07:40 PM
DrewMan's Avatar
Culpam Poena Premit Comes
The lower the octane rating, the more prone the engine will be to knocking/pinging (early detonation)
not good!
Use the highest octane rated fuel you can get and you should be fine
Old Dec 26, 2008 | 07:42 PM
StealthTL's Avatar
Metatron
I make gasoline for Shell - UserrName and dannobre are spot-on, RON is usually 4 or 5 numbers higher than R+M/2
So minimum 97....
S
Old Dec 26, 2008 | 08:24 PM
erx8s's Avatar
January 5th will be TEN-months and counting, since I ordered and paid for a MazdaManiac turbo upgrade kit."
At least you didnt put the money in to the share market
10 Months for a turbo kit is a hell of a long time to wait
Cheers
Michael
Old Dec 27, 2008 | 02:38 AM
auzoom's Avatar
Hmmmmmm.........
JDM model is not the same as we get in AU. The fuel available in Japan is much better quality and higher octane (Japanese use RON dont they?). I wouldnt touch the 88 RON.
Cheers
Andrew
Old Dec 27, 2008 | 05:35 AM
takahashi's Avatar
Hi Oct in Japan is 102RON. So the higher the better.
Old Dec 27, 2008 | 05:36 PM
Revolver's Avatar
I think he's got the message...
Old Dec 28, 2008 | 08:24 PM
Cromax's Avatar
Buzz Buzz Buzz
Hmm ... maybe he should use AvGas then?
Old Dec 28, 2008 | 08:43 PM
auzoom's Avatar
Hmmmmmm.........
That would be 130 RON
Old Dec 28, 2008 | 09:08 PM
Cromax's Avatar
Buzz Buzz Buzz
Not quite ... it's 100 RON (for the low lead one at least).
Old Dec 28, 2008 | 10:42 PM
auzoom's Avatar
Hmmmmmm.........
Hmmm well actually we are both right but technically I think you are . 100 is the rating used under similar condition to the MON rating, the 130 rating is under "supercharged condition with a rich mixture, elevated temperatures, and a high manifold pressure" (thanks wikipedia). I never knew there was 2 and my father is a pilot and he always talked about avgas being 130...so there you go! Learn something new everyday :p
Cheers
Andrew
RevMeHarder
Jun 1, 2026 02:30 PM
OnebaddRx8
Aug 25, 2019 11:34 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
