Lucas UCL?
Old Dec 23, 2008 | 12:40 PM
learycd's Avatar
Hold DSC for 7 Sec
Lucas UCL?
ok so was reading a post that said lucas oil upper cylinder lube contains stuff that can eat away at the seals. that kinda claim is worth asking more about...
everything else ive read says UCL is a good, clean burning pre mix. is there any danger to the seals/engine from lightly premixing UCL?
thanks guys, i just wanna know if this is for real or not before i pick up another bottle of it. pic below for fun:
Old Dec 23, 2008 | 12:54 PM
Derex'8's Avatar
ReDuX
Really?....I've been premixing w/this stuff for quite a while now w/no problems
Old Dec 23, 2008 | 01:00 PM
learycd's Avatar
Hold DSC for 7 Sec
i know, same with me, and i cant think of any reason why it would eat at the seals. i mean yeah its suppose to get rid of deposits so it has to have some sort of compound that removes them. however it cant be so strong that it eats away at our seals too because then it would damage other components in normal engines as well.
so could you guys weigh in? any truth?
Originally Posted by Razz1
Upper cylinder lube contains solvents that are bad for the seals.
Old Dec 23, 2008 | 01:33 PM
skrubol's Avatar
A while back in the premix thread some said that mixing UCL and 2-stroke as pre mix caused fuel filter clogging. Last I knew that wasn't really proven or disproven, but I will usually do a few tanks with UCL, then several with 2-stroke, using both, but never really mixing.
Old Dec 23, 2008 | 04:31 PM
learycd's Avatar
Hold DSC for 7 Sec
so im assuming no immediate danger from UCL and my seals?
anyone else?
Old Dec 23, 2008 | 04:45 PM
StealthTL's Avatar
Metatron
I've used it pretty heavy, since day-one.
It is very lubricious and burns cleanly, it's based on a polymer called polyisobutylene and certainly won't harm any baby seals!
S
Old Dec 23, 2008 | 06:24 PM
learycd's Avatar
Hold DSC for 7 Sec
AWESOME! just wanted to hear it again
i actually just went out and bought another big jug of it.
steath speaks: baby seals + UCL = as safe as KY
Old Dec 29, 2008 | 05:33 PM
Stealth, have you ever had your fuel pump replaced? Do you track your car at all? How much of the UCL do you mix with a fill up?
Old Aug 3, 2009 | 09:10 AM
8upbad's Avatar
Jared
I'm reviving this thread just as a heads up. I am starting my premix today. I have an 05 6speed with 55K. I have Pennzoil Marine Premium Plus Synthetic and I am mixing it with Lucas UCL. At this point I have a gallon of the Pennz and 32 oz of Lucas UCL, so what I am planning on doing is just mixing the two together and using the UCL bottle as my measuring cup.
Old Sep 11, 2009 | 05:33 PM
How did mixing the pennzoil and Lucas go? Stealth can you comment on my previous question?
Old Sep 12, 2009 | 09:15 AM
8upbad's Avatar
Jared
FL
I've been using this setup for about a month and it's great. I haven't tried anything else yet but no issues so far.
Old Sep 12, 2009 | 09:50 AM
At what ratio are you mixing? And how many ounces are you adding per tank?
Old Sep 13, 2009 | 07:26 AM
8upbad's Avatar
Jared
FL
I bought a 32 Oz bottle of the Lucas and added it to a gallon of the Pennzoil 2-cycle marine oil. I use the Lucas bottle to measure out about 12 ounces and that will last two tanks. I have done as much as 10 ounces in a tank and as little as 4.
Old Sep 13, 2009 | 08:02 AM
StealthTL's Avatar
Metatron
Sounds like a great mix.
Had a new pump, but only because the old one burned out.
Sock gets dirtier than average, so I clean annually.
Old Sep 13, 2009 | 10:16 AM
NOTURX8's Avatar
I've been premixing for quiet 3 years now, and no problems at all
2oz Lucas High Boost Octane
2oz Lucas UCL
2oz Penzoil or Castrol 2 stroke
I only input 6oz each time I fill the tank... there are a lot of ways to use UCL, but I'm sure you can check the Premix Thread for more info....
Old Sep 26, 2009 | 08:05 PM
Any point in premixing the premix?
Old Nov 10, 2012 | 06:04 PM
1RadRotary's Avatar
Can you just use the Lucas ucl by itself? If so how much per full tank?
Old Nov 10, 2012 | 07:43 PM
StealthTL's Avatar
Metatron
Yes, UCL is fine on it's own, it's based on PolyIsoButylene, a very slippery chemical synthesized from natural gas.
Old Nov 10, 2012 | 08:04 PM
1RadRotary's Avatar
Thanks! But how much do I use per full tank?
Old Nov 11, 2012 | 12:36 PM
1RadRotary's Avatar
Anybody know?
Old Nov 11, 2012 | 02:29 PM
xexok's Avatar
Well if it is like any other premix out there then people usually go a half ounce per gallon of fuel. Check https://www.rx8club.com/tech-garage-...99636/page144/ if you really want to know.
Old Nov 24, 2012 | 02:52 AM
Demon87's Avatar
Wicked Performance
I always use the UCL never had any problems. I have no idea who or why someone said it would eat the seals. It is a type of oil. it is not like Seafoam which is a heavy duty cleaner, which over time with use will eat rubber and plastic. Put some in a foam cup and see what happens, it will also eat paint. Seafoam is ment to be used as needed to clean valves and lines, lucas is ment to be used all the time, or every cpl tanks. I had my engine rebuilt after 130k and hardly any wear on it!
Old Nov 24, 2012 | 08:01 AM
Then why rebuild it?
There is nothing more ridiculous than a bunch of backyard mad scientist hacks thinking that a conglomeration of crap they bought off the shelf at Walmart is a magic ellixer for their engne
Old Nov 24, 2012 | 09:23 AM
ken-x8's Avatar
Originally Posted by TeamRX8
...There is nothing more ridiculous than a bunch of backyard mad scientist hacks thinking that a conglomeration of crap they bought off the shelf at Walmart is a magic ellixer for their engne.
Exactly. Stick to proven products that are promoted on infomercials.
One serious (sort of) question about UCL. Is this meant to be mixed with gas for use in two stroke engines? So should I use it in my week whacker instead of the stuff labeled "two stroke oil" that I buy at Home Depot?
Ken
OnebaddRx8
Aug 25, 2019 11:34 PM
Fister_Roboto
Aug 4, 2015 03:42 PM
cwatson
Apr 15, 2012 10:38 AM
User24
Nov 23, 2010 09:13 PM
MikeTyson8MyKids
24
Jul 27, 2010 01:30 AM
