tb porting
Old Dec 22, 2008 | 01:47 PM
G3RX8's Avatar
tb porting
was wondering if anyone has ported there throttle body and noticed any thing.... i saw that someone did it on the forum for 150 bucks but i havent heard of any responses from it. i was thinking about doing this over winter break while im at the inlaws. thanks
Old Dec 27, 2008 | 11:52 AM
Charles R. Hill's Avatar
Owner of BHR
I believe he was offering polishing services........
Old Dec 27, 2008 | 05:01 PM
kersh4w's Avatar
Hit & Run Magnet
right, you polish the TB and port the exhaust.
i never heard of porting the tb...
Old Dec 27, 2008 | 05:10 PM
bse50's Avatar
#50
FEED\Fujita eng. sells a "bigger" throttle body at an insane price. It has got a 2mm bigger bore.
By the way, remember that not always a very smooth, polished surface will help the flow if i remember right. There are times where the right porosity is better (especially with air\fuel mixtures but that's not the case).
I hope that somebody will explain this better than me though
Old Dec 27, 2008 | 05:14 PM
Owner of BHR
True. If the TB is larger than the manifold itself things flow may diminish.
The concept that rough surfaces flow better than smooth ones is called "boundary layer effect" and it is what makes golf ***** fly in particular manners and different trajectories.
Old Dec 27, 2008 | 05:25 PM
bse50's Avatar
#50
Yes, plus if you have a fluid or a mixture flowing somewhere if you have some calculated porosity you create a thin air cushion that speeds things up.
Like playing Air Hockey but you don't brake anything :p
Old Dec 27, 2008 | 05:26 PM
Owner of BHR
I think the idea is that it is easier for a given fluid to flow over itself rather than a foriegn material like metal as the fluid held in the pockets doesn't flow.
Old Dec 27, 2008 | 05:42 PM
bse50's Avatar
#50
If we're talking about air yes, but if it is a mixture or a liquid the small porosity (not a machinegunned wall ) will retain air. That's where the air cushions come frome. Then the mix should be able to move\flow over the thin layer of air without being slowed down by the "superficial" particles slowed down by the metal. Some porosity also helps avoiding condensation.
These differences are so small that you don't even notice them on a flowbench so polishing might be a good solution.
I apologize if i made mistakes in the explanation but that's pretty tough to explain in a different language.
Old Dec 27, 2008 | 05:47 PM
Owner of BHR
Originally Posted by bse50
If we're talking about air, yes.
Throttle bodies are intended to flow air aren't they?
BTW, I will be trying out a polished TB soon.
Old Dec 27, 2008 | 05:51 PM
bse50's Avatar
#50
Yes, that's why i said in my first post that this is not the case
A polished throttle body? Have a Holiday and try mine out :p
There's not much of a difference in terms of g\cm^2 of flow but it's still something especially when you are tracking the car at high rpms for a long time.
Old Dec 28, 2008 | 08:51 AM
G3RX8's Avatar
Thanks for all your guys help just got finished my polishing I think I did a good job very smooth and I took care of that ridge on both sides
Old Dec 28, 2008 | 09:37 AM
bse50's Avatar
#50
Have you got pictures or any impressions?
I left the ridge there though
Old Dec 28, 2008 | 10:55 AM
G3RX8's Avatar
I Am at my inlaws house I don't have my camera but I can get some up next week. Did you notice any inprovmemts in the car after putting it on. I don't know if it is going to be much better but it can't hurt.
Old Dec 28, 2008 | 10:59 AM
bse50's Avatar
#50
Removing the ridge\restriction could affect the low end response and maybe the idle. I'm not sure, so i just left it there. The increase is so small you probably won't feel it with your back :p an obd scanner will tell you more with a before\after test.
Still, it is nothing like oh my god, vtec just kicked in!
Old Dec 28, 2008 | 11:11 AM
G3RX8's Avatar
I didn't touch were the butterfly sits and the guy that offers to polish them got ride of the ridge so I. Didn't think it was that big of a deal
Old Dec 28, 2008 | 11:17 AM
ShellDude's Avatar
weeeeeeeeee
heh... he said "vtec"...
after following the other thread I decided this one needed pictures too.
Old Dec 28, 2008 | 11:21 AM
bse50's Avatar
#50
It is not a big deal indeed, and if somebody does it without issues then it is good to know
That's why i demand pictures now, i want to have a closer look at your work
Old Dec 28, 2008 | 12:32 PM
G3RX8's Avatar
I'm sorry I wish I could I will have them up soon
Old Jan 1, 2009 | 07:06 PM
04RX8man's Avatar
Rotary Powered Countryboy
Vtac!!! Ftw
Old Jan 4, 2009 | 05:41 PM
G3RX8's Avatar
The throttle body works good nothin crazy but the intake is louder no problems
Old Jan 4, 2009 | 06:15 PM
04RX8man's Avatar
yeah anytime ur getting more air in faster it's going to b louder for sure!
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Evan Gray
Nov 24, 2015 01:00 AM
bosstin87
Oct 5, 2015 06:52 AM
Stubbs
Sep 27, 2015 04:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
