raidator light??
Old Dec 16, 2008 | 12:15 AM
jeffRX's Avatar
Black on black on black..
raidator light??
So I'm driving on I95 and I happen to notice my radiator light turn on... staying lit, I start worrying but it turned off after only a few seconds... it's happened one more time since then... what is this?? I've checked the level of coolant and ALL fluids and everything looks peachy... help please
Old Dec 16, 2008 | 12:21 AM
elysium19's Avatar
I guess the only thing I can say is that the coolant tank is slightly confusing, at least on mine (an '04) it is very thick and you can barely see light through it, and it makes it very hard to tell if it's low. If you're sure it's not low.....then......no further ideas from me, sorry
Old Dec 16, 2008 | 12:18 PM
Old Rotor's Avatar
Add water to the reservoir and most likely it will go away. If not you might have to replace the reservoir, there are a few bad ones out there.
Old Dec 17, 2008 | 01:14 AM
wow,
all that info.. like what year is the car. how many miles..
if it is an 04 with over 50k miles on it. a know issue with the sensor exists..
Old Dec 29, 2008 | 12:44 PM
Geforce07's Avatar
'04 Ti Gry MT > All
Ya mine is doing this too, probably need to clean the sensor idk. I need to get it figured out
Old Dec 29, 2008 | 12:50 PM
dozer's Avatar
on his 3rd rx8
everything should be fine as long as you got fluids in there...just make sure you arent leaking or anything ....ive read that the sensors tend to go bad
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
