Midpipe+ 02 sensor spacer= no CEL?
Old Dec 13, 2008 | 10:11 AM
ryebread929's Avatar
Exclamation Midpipe+ 02 sensor spacer= no CEL?
hey guys i searched the threads and i cant find the exact answer i was looking for so ill post up.
i have a 04 MT 8 with 35k miles, K&N Typhoon intake, and a magnaflow catback. im looking to go to a rx7store.net catless midpipe, and by re installing my 02 sensor with a spacer like the ones found on ebay etc for 20.00 has anyone had any experience with these. i want to do it but i dont want a CEL, the spacers description states it is for high performance exhaust with no or a high flow cat for the rear 02 sensor. it basically threads into the catless midpipe and then u thread the sensor into the spacer. i just want to make sure it works. thanks in advance!!
-Ryan
Old Dec 13, 2008 | 11:15 AM
chancejat's Avatar
Drive it like u stole it!
works if your lucky.....id say 1 in 50 cars
Old Dec 13, 2008 | 11:33 AM
04RX8man's Avatar
Rotary Powered Countryboy
not sure if this will work or not
Old Dec 13, 2008 | 11:36 AM
More likely to work on 04's...but like chance said about 2%
Old Dec 13, 2008 | 11:49 AM
laythor's Avatar
I zoom therefore I am.
could always get the mazdamaniac cobb access port and it will mask your cell
Old Dec 14, 2008 | 11:08 PM
nobody has any experience with the 02 spacers?
Old Dec 14, 2008 | 11:21 PM
Didn't work for me
Flashwing's Avatar
3-wheeler
I didn't use a spacer but I installed a spark plug fouler which was supposed to have some of the same effect. It was a trick used on MS Protege's. Instead the PCM reported a CEL that the front and rear O2 sensors were reporting inconsistant Air/fuel ratios.
The best way to deal with it is to use the Cobb Accessport to have the CEL removed. Otherwise if you have to have emissions checked they will fail you for the Check Engine Light.
I drove around with a mid-pipe CEl for about 2 years and traded it for a TPMS sensor.
Old Dec 14, 2008 | 11:23 PM
MazdaManiac's Avatar
Yes. We do.
As Dan said, it will most likely work with the '04, but even then with only a very small success rate.
If you are lucky, you might have one of the '04s that just isn't all that sensitive (like mine) and not need the bung extender.
If it does set a CEL, I'd say its one in 50 or so that you can extinguish it mechanically.
Then again, since you are not interested in performance, just putting a piece of tape over the light will probably do just as well and has a 100% success rate.
Old Dec 14, 2008 | 11:41 PM
good to know. guess its going to be a roll of the dice when i install it
Old Dec 15, 2008 | 07:11 AM
RX8-Frontier's Avatar
Well, if a spacer doesn't work, then pickup an O2 simulator (essentially just a resister that goes in place of the rear O2 sensor that causes a "good" reading to be sent to the computer). They're usually around $70 or so, tops.
Old Dec 15, 2008 | 11:02 AM
Uh, no.
Those don't work on the RX-8. This isn't 1992.
Old Dec 15, 2008 | 02:34 PM
The computer is way too smart for that...it alters the A/F ratio and expects the the front sensor and the rear to change in a logical manner....when it doesn't it blows the whistle so to speak. Because the front is a current based WB and the rear is a voltage based NB it isn't so easy to fool like the old systems with just a narrowband
Old Dec 15, 2008 | 02:41 PM
im now looking at a SR motorsports high flow cat instead of a catless midpipe. hear it still sounds good and shouldnt throw a light, might need the spacer though.
Old Dec 15, 2008 | 02:45 PM
That will work for a while A lot of the less expensive high flows burn out....
Old Dec 15, 2008 | 02:47 PM
shows it as 599.00 on srmotorsports website.... doesnt seem cheap to me lol!
but i try and look for deals as it is.... got my typhoon intake for 180 new, and my magnaflow catback for 600 new. im frugal so to speak but i still want good brands hahaha
Old Dec 15, 2008 | 02:51 PM
Cheap does NOT equal inexpensive.
Old Dec 15, 2008 | 04:47 PM
dozer's Avatar
on his 3rd rx8
ive had my turbo xs midpipe on for about month now...just plugged in the sensor and no CEL as of yet
Old Dec 16, 2008 | 12:11 AM
jeffRX's Avatar
Black on black on black..
Originally Posted by MazdaManiac
Yes. We do.
HAHA nice... I might do this mod
Old Dec 16, 2008 | 12:17 AM
I was trying to be tactful...careful choice of words
Old Dec 17, 2008 | 01:23 AM
better choices out there. if you are frugal keep the stock cat in place. it will do you well.
Old Jan 26, 2009 | 06:39 PM
well i bought a midpipe.... its the rx-7store midpipe with high flow cat.
ill get it installed when it isnt 5 degrees out and i can actually stand to take the 8 out of the garage and uncover it..... spring wont come soon enough...
hopefully no CEL once its in, then onto headers?
Old Jan 27, 2009 | 10:23 AM
Uh, no.
You're right. You need a rectifier diode to make a voltage drop instead of a current drop like the old resistors did. My bad...
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
Evan Gray
Sep 26, 2015 12:30 PM
