water leak in car
Old Dec 11, 2008 | 04:48 PM
DjXl28's Avatar
water leak in car
Just wondering if any had or knows about an issue I have which is, water is pooling up on the passenger side between the front & back seat, it only happens when its a steady rain for an hour or so, took it to the dealer, they couldnt find anything. i made a slit it the carpet & i caught it once while it was happening i saw the water trickling from the front. any ideas?
Old Dec 11, 2008 | 05:01 PM
Silver06's Avatar
Zoom Zoom....
First, check the airconditioner condensate drain tube. Next, do you have a sunroof? Check the drain tubes. Also, pull up on the rear seat lower cushion to see if it's wet on the metal underneath.
Unfortunately, unless source of the leak is really obvious, water can travel a distance to a low spot before puddling. It's a pain, but the interior will probably have to come out.
I'd bet (hope) it is the above drains, though.
ps. Year and location of your car, please. This is covered under the Basic Warranty. If it is warranty, don't accept that they can't fault!
Old Dec 11, 2008 | 05:52 PM
invasion08's Avatar
Sit in the car and have someone else spray the car with a hose over everyplace the car could leak and see if you see any water entering
Old Dec 11, 2008 | 05:56 PM
DjXl28's Avatar
thanx , do u know where the sunroof drain tubes are located, cuz I made a big enough slit & i saw the water streaming in from under the front seat
Old Dec 11, 2008 | 06:04 PM
Silver06's Avatar
Zoom Zoom....
For the Front drains...
1. Remove the following parts:
(1) Roof side trim
(2) A-pillar trim
(3) Rear seat
(4) Inner scuff plate
(5) Tire house trim
(6) Rear pillar trim
(7) Map light
(8) Interior light
(9) Sunvisor
(10) Assist handle
(11) Headliner
2. Disconnect the front drain hose from the sunroof frame.
3. Remove the front drain hose from the clips.
4. Pull the front drain hose into the vehicle interior and remove the front drain hose.
For the Rear, do the same steps ....
Old Dec 11, 2008 | 06:13 PM
DjXl28's Avatar
thanx, looks like it could be the front hose, i'll try it out or suggest to the dealer.
Jesus Martinez
44
May 6, 2025 08:09 AM
9krpmrx8
Nov 5, 2015 11:45 PM
marc2820
Jul 26, 2015 10:47 PM
westgman
Good Guy/Bad Guy
Jul 15, 2015 11:18 PM
