power surge went from 4800 to 6800 rpm
Old Dec 10, 2008 | 09:16 PM
Silver06's Avatar
Zoom Zoom....
Please be more specific on what the dealership did. Did they replace any parts?
There are two valves in the intake manifold. Both are ECU monitored / controlled - so would've thrown a CEL.
One (the APV) is an electrically-driven motor, the SSV is a vacuum damper. Both of these affect the powerband.
The APV I think opens at 7,200 rpm. The SSV opens at about the same time as the secondary fuel injectors start going (depending on engine load; between 3,200 and 5,500 rpm).
Did you have the car before this fix? (are you the original owner?). If not, I think what you are feeling now is the Zoom Zoom of the APV actually working properly.
You could do a search for: "APV" and "SSV"
Old Dec 10, 2008 | 10:24 PM
Silver06's Avatar
Zoom Zoom....
I'm not entirely sure, and I'll wait to be corrected, but I don't think the purge solenoid valve being stuck would have anything to do with the engine powerband noticeably changing at high revs under load (ie:not in vacuum).
However, two failures of that same part in short succession leads me to think that there may be other problems going on.
Old Dec 11, 2008 | 11:57 AM
zoom44's Avatar
i bet you were missing power before below 4800 which is why it felt like a surge. now that its fixed you get the normal surge from the intake opening at 6500
Old Dec 13, 2008 | 11:50 AM
04RX8man's Avatar
Rotary Powered Countryboy
You will fee the bggest "surge" at about 6500rpm when the last set of injectors kick in
RevMeHarder
Jun 1, 2026 02:30 PM
gwailo
May 14, 2024 06:57 AM
WranglerFan
May 31, 2022 07:51 AM
DVerdeyen
Sep 13, 2015 11:19 AM
GARCIAC951
Sep 10, 2015 07:17 PM
