New MazdaManiac BASE Calibrations
Old Dec 31, 2008 | 04:07 PM
  #251
\\Konig\\'s Avatar
turrrbo!
Hey jeff,
if i get my turbo installed before getting it tuned on the socal dyno day and drive an hour on the freeway with the basemap installed will that damage anything?
Old Dec 31, 2008 | 04:12 PM
  #252
MazdaManiac's Avatar
Originally Posted by \\Konig\\
Hey jeff,
It should drive almost perfectly on the base map. Its not dangerous.
In fact, its not far off what the final tune would be, pending proper MAF and injector scaling.
Old Dec 31, 2008 | 04:18 PM
  #253
\\Konig\\'s Avatar
turrrbo!
okay good to know!
id be using the AEM intake and stock injectors
Old Dec 31, 2008 | 04:23 PM
  #254
okay good to know!
Then, just download the appropriate base calibration and go with it.
As always, be cautious going into boost and start with the lowest possible boost setting until you are certain that the boosted AFRs are at least 12:1 or less.
You may see boosted values as low as 9:1!
I try to put the base calibration fuel values in a range that yield about 10.9:1, but MAF and injector variations screw with that quite a bit.
Old Dec 31, 2008 | 04:32 PM
  #255
\\Konig\\'s Avatar
turrrbo!
okay, thank you very much jeff! =)
Old Dec 31, 2008 | 04:43 PM
  #256
alienRX8's Avatar
Boosted!!!
Yeah Konig it should work. I had that same base map when I installed the turbo. So its good to go.
Just drive carefully like Jeff says
Old Dec 31, 2008 | 06:44 PM
  #257
shaunv74's Avatar
Power!!
I just submitted my idle and cruise datalogs for scaling. Definitely a smoother process.
Old Jan 1, 2009 | 12:45 AM
  #258
hakuna matata!
I know this has been asked once before but I just wanted to clarify.. replacing my CAT with a midpipe (mazsport, in this case) will not require a new tune correct? It will just "make available or free up" horses that the engine already puts out, yes?
Old Jan 1, 2009 | 11:08 AM
  #259
ShellDude's Avatar
weeeeeeeeee
I'll tell ya in a week weather permitting. Jeff has stated ad nauseum that a new tune is not required.
Old Jan 1, 2009 | 12:01 PM
  #260
Mr.&Mrs.Magic's Avatar
Jeff I think I messed up
You sent me my first updated base calibration on 17 Dec and after running it for a few days I sent you the loggs LTFT was at -0.94. <- This is where I messed up I think. When sending the 11 Deadly Questions I left out my Turboxs exhaust that was sent for the previous calibration on 17 Dec. The current cailbration in question was recieved on 25 dec. I sent you an email on 29 Dec with proper loggs and the 11 questions voicing my concern as the LTFT was now at 5.3 and since sending the email it has gone to 7.
Just trying to let you know that I left out the exhaust in my previous email and this maybe the reason the ltft is off.
SIDE NOTE- I have a huge hangover and this seems hard to read. Is it?
Old Jan 1, 2009 | 04:42 PM
  #261
neXib's Avatar
We're supposed to watch our ltft? I'm just looking at AFR :P (though I browse everything when sending logs to Jeff)
Old Jan 1, 2009 | 05:02 PM
  #262
Yes and No. That's what the inital idle loggs are for once you get past that then you done with fuel trims unless it goes grossely off. He recals the MAF so your fuel trims are closer to +/- a few of 0 then on to WOT logging which is where i was till I screwed the pooch. Mine were close but now not so much. On the other hand he may have put it there for a reason and my missing the exhaust in the 11 questions has nothing to do with it.
Your watching your AFR so you don't blow your motor.
Old Jan 1, 2009 | 05:07 PM
  #263
ShellDude's Avatar
weeeeeeeeee
Actually, running NA watching your AFRs isn't out of fear of blowing your engine. Our cars are factory / recall tuned so friggin rich that it takes forever to get it leaned properly... at least that's what I would call typical for us.
Old Jan 1, 2009 | 05:14 PM
  #264
Some cars a weird though and this is why we watch. I had a problem for a bit of going well into the upper 16's low 17 under wot. Hot day, bad gas and AFR of 17 can = have a nice day.
Old Jan 1, 2009 | 06:14 PM
  #265
First of all, exhaust doesn't matter at all.
Let me see if I understand what has transpired.
You loaded v4.0, ran it and sent me logs. I sent you v4.0.1 and you sent logs again based on v4.0? Now you are on v4.0.2 and the LTFT is +7?
You need to start over again. I do not maintain a file trace - just the last version and it assumes good logs based on the preceding version.
Old Jan 1, 2009 | 06:45 PM
  #266
I loaded v4.0, ran it and sent you logs. You sent me a v4.0.1 at which point ltft was at -0.94 and then I sent you the logs which excluded exhaust "which doesn't matter now. You then sent me a v4.0.2 and stated to start the wot operations. This is the most current version(v4.0.2) which has Ltft currently at +7.
So how about we just start over right?
Old Jan 1, 2009 | 06:56 PM
  #267
You can just send me your previous logs for v4.0 and I'll send you a new v.4.0.1 and see what happens.
You shouldn't need to go through part 1 again.
Just make sure you point out that the logs were your first set (for v4.0.) and not something else.
That will save you some time.
Old Jan 1, 2009 | 07:00 PM
  #268
L337fpc's Avatar
ლ(ಠ益ಠლ)
Hey Jeff,
I'm pretty anxious for these maps...
  #269
cool beans done and done.
Old Jan 1, 2009 | 07:54 PM
  #270
Got it.
Old Jan 1, 2009 | 11:15 PM
  #271
shaunv74's Avatar
Power!!
Originally Posted by L337fpc
Hey Jeff,
Today is a holiday. Jeff may be taking the day off like the rest of us.
Old Jan 1, 2009 | 11:35 PM
  #272
L337fpc's Avatar
ლ(ಠ益ಠლ)
I know I know.
Old Jan 3, 2009 | 12:42 AM
  #273
Jasonawojo's Avatar
Just checked out my logs and noticed the idle ltft got much worse with the 4.0.2 (+20), while in the other logs it went from negative a few to positive a few.
Oh, in between getting the tunes back I've been going back to my other tune since I've been driving a lot lately. The limit to the number of times you can flash is way off into the thousands right?
Old Jan 3, 2009 | 12:46 AM
  #274
there's a limit?
Old Jan 3, 2009 | 12:49 AM
  #275
paulmasoner's Avatar
Asshole for hire
Originally Posted by Jedi54
there's a limit?
any flash memory has a flash limit at which point stability becomes an issue, i remember it being talked about on here before in the early AP days, but dont know if anything better than "dont worry about it" was reached
