Cold Start Potential Issue
Old Dec 6, 2008 | 09:29 PM
evoego17's Avatar
I've got my '04 8 in some seriously weather for the first time and I'm unfamiliar with the expectations for a cold start after a few days of mid-teen level temperatures. I anticipated that the start up would be slow simply based on the fact that I only get the chance to drive my car once or twice a week, but is a full 2-3 seconds from key turn til turn-over normal for these conditions? I've also heard that Mazda has an improved start motor available on later model years. Is that something worth looking into, or is my potentially slow start up a nonissue?
Thanks in advance.
Old Dec 6, 2008 | 09:36 PM
04RX8man's Avatar
Rotary Powered Countryboy
that does not seem to be bad at all....the 04's had a TSB for an updated starter/battery/spark plugs....call your closest dealer and see if ur car has had it.....i never had the starter TSB done and never had a problem in the cold when i lived in the north!!!
Old Dec 7, 2008 | 07:34 AM
VOODOO8's Avatar
Hermitage Holdout
As you can see, I do live in a state that sees some seriously cold temps in the winter. I had the starter upgrade done on my '03 build and it has fired like a champ ever since, even in negative number temps that were cold enough to whack out the dashboard electronics and stiffen the cones on the speakers to uselessness.
Just tell the dealer you have a hard start condition, some magic words to trigger the option for the starter upgrade on the TSB that went with it.
Old Dec 7, 2008 | 09:58 AM
04RX8man's Avatar
yeah a few keywords at the dealership and u will have the new starter installed and maybe new plugs and battery....
Old Dec 7, 2008 | 11:55 AM
alnielsen's Avatar
It was down to 1F this morning here and mine had no problems starting. While it was in warranty, the starter TSB was performed.
Old Dec 7, 2008 | 12:26 PM
evoego17's Avatar
Thanks guys! Sound like I need to just work some magic on the dealer.
Old Dec 18, 2008 | 02:32 PM
dtrmnd's Avatar
getting the dealer to replace the starter, plugs, etc is simple but be careful because you might have the same problem again....i am...
Old Dec 18, 2008 | 08:20 PM
05rx8mazda's Avatar
B.I.G
my car is used to texas weather and i just got into illinois where the temperatures are in the teens..
i turned it off for a couple of hours and when i turned it on to move it it hesitated to start and A TON Of white smoke came out the exhaust and smelled like something was burned like burnet oil pretty much and then it had a loud ticking noise like i had a spun bearing...
TICK TICK TICK TICK.. and the motor was vibrating violently..
no power and it felt like it wanted to shut off when i would take off and it would not rev past 7K rpm.
drove it around the block and revved it up a lot and it backfired SOOO much and that seemed to fix the problem. hasnt come back since them and this was about 3 days ago.
Old Dec 19, 2008 | 12:16 PM
dtrmnd's Avatar
this is the second time for me.....the first time was my fault. I started it up and shut it off after about 2 minutes. i had it towed to the dealership and they said that everything would be covered except the tow....just once.....after that i would have to pay for everything...
Old Dec 19, 2008 | 02:15 PM
evoego17's Avatar
I've had the plugs and the ECU reflash done just not the starter. It just seems very labored in turning over. I havent experienced that white smoke or backfiring, luckily.
Old Dec 22, 2008 | 05:35 PM
Grimacus's Avatar
I've just had the same problem last night, car sat overnight here in Fort Worth, Texas and temps have been below freezing last couple nights. So I went out to start the car, and it took a couple cranks, then when it did start, it felt backed up, like someone stuck a banana in my exhaust. The car would sputter, make some thud sound and the car would vibrate, when I rev the car to 3k+ the car would shudder/vibrate worse. Also noticed lack of power while driving, of course after about 20 minutes of driving it got better.
Old Dec 22, 2008 | 07:16 PM
dtrmnd's Avatar
Does anyone know how hard the de choke procedure is on the motor?
Jaco Greyling
Jan 6, 2019 08:39 AM
IamFodi
Series II Interior, Audio, and Electronics
28
Oct 31, 2018 06:37 AM
Redheddude222
Aug 24, 2015 09:14 AM
dbarber
Jul 25, 2015 01:34 PM
AussieGray
Jul 16, 2015 03:58 AM
