new cd player ?
Old Dec 4, 2008 | 07:00 PM
wassup_nuthin's Avatar
new cd player ?
Ok i have the metra kit for my rx8 and just installed a cd player and the kit today in my car. Now my question is theres a buzzing noise in my speakers at low volume, *you can hear it at higher volume* or fuzzy noise. wouldnt you say i have a bad cd player? the metra kit is used but i dont think it is causeing this noise. all the wires are correct and solid.
pretty much i just need some reasurance that it is prolly my cd player and i just need to replace it.
Old Dec 4, 2008 | 10:16 PM
firebirdude's Avatar
User and Abuser
Does the buzz itself increase and decrease when you adjust the volume **** on the player?
Does the buzz exist on all sources of audio? Tuner? CD player?
Does the buzz exist whether the car is running or off?
Does the buzz vary with engine RPM?
Old Dec 5, 2008 | 01:54 AM
buzz is the same, only when cd player is on. it is on all the sources, i dont think it changes w/ rpm. the only time the buzz changes is when you change the source on the cd player. when you adjust the volume **** it dont decrease but you cant hear it when the music is loud. Im pretty sure its the cd unit but i could be wrong. what else could it be?? everything is hooked up solid and right.
Old Dec 5, 2008 | 09:26 AM
User and Abuser
Move the headunit's ground wire to a different location. If you're using a factory ground wire in the harness, try connecting it directly to metal in the dash.
drebbrnator
Dec 27, 2018 07:02 PM
vapor2
Jul 9, 2016 07:35 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
04MazdaMan
Jul 15, 2015 08:23 PM
lbrintle
13
Sep 17, 2003 12:04 AM
