HKS TWIN Power Problem
Old Nov 29, 2008 | 01:33 AM
CostasX8's Avatar
2003 Titanium Grey JDM 6M
I installed the HKS Twin yesterday and when i tried to start the car all the needles on the panel where going up and down and i didn`t have any power.After a few minutes the car started so i gave no attention to it. Today i tried to start the car and again same problem,no power for a few minutes.It is like the ECU is restarting or something... Any ideas will be help full
P.S I connected the coil plugs correct T-L and also grounded the HKS.
Old Nov 29, 2008 | 04:52 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
installed mine for over a year and a half and never had a problem. but i suggest you to probably check your plugs again and make sure its in the right order. i will try and snap you a pic if i have time.
Old Nov 29, 2008 | 05:27 AM
StuttgartRX8's Avatar
Nurburgring Camera Whore
I've never had a problem with mine either, check the connections.
Old Nov 29, 2008 | 10:00 AM
Before you installed the twin power I hope you checked your coils. That would have been the perfect tiem to do so, and make sure they are in the correct order. It can happen..
Old Nov 29, 2008 | 10:40 AM
Race Roots's Avatar
Former Sponsor
Sounds like a bad ground. Check the connection.
Old Nov 29, 2008 | 04:13 PM
CostasX8's Avatar
Thanks for all the info!
For the coils i don`t think there is a problem(worked fine 5 minutes before)
The connections i would double check tomorrow but it is basic...White Tie - Black Tie
Might be the grounding.Couldn`t remove the ground screw so i drilled a screw for mounting the HKS and put the ground wire between the chassis and HKS.
Old Nov 29, 2008 | 04:15 PM
Sounds like your problem then....that will be a very poor ground...unless you sanded off the paint to bare metal.....but it's more likely your battery ground...or connections. The HKS ground shouldn't effect the whole electrical system
Old Nov 29, 2008 | 04:22 PM
CostasX8's Avatar
Bad ground only for the twin power,
Maybe because the power goes threw the twin power and after to the coils and the twin power is not grounded well, it might creates this "restart".
Will have to check it tomorrow and let you know what was the problem.
Old Nov 29, 2008 | 08:01 PM
Race Roots's Avatar
Former Sponsor
The same thing happened to my car with the Needles.
The terminals on the battery ground were rusted and once I cleaned it up and replaced some parts, it had a much stronger ground, and started like normal.
Old Dec 2, 2008 | 06:28 AM
CostasX8's Avatar
Yep, it was the grounding!
Thanks for the help
xAgyex
Jun 3, 2026 03:47 PM
jay_tibo
22
Sep 13, 2016 08:10 PM
Jazzmeson
Aug 6, 2015 04:34 PM
Jazzmeson
Aug 6, 2015 04:32 PM
N0P1st0ns
Jul 30, 2015 09:45 AM
