Need Help with Turbo setup
Old Nov 27, 2008 | 03:41 PM
DJ_Skyhawk's Avatar
Rotary Head
Exclamation Need Help with Turbo setup
Hello, I'm curious about something, why is it when I set my BOV to the lowest setting on my GReddy turbo setup and rev the engine the rpms drop down to almost 0 and sometimes the motor actually stalls out for no reason, however I put my BOV to almost the hardest setting and it dosent happen anymore, however I'm not running enough psi of boost to really hear any sound at that level I really miss the whistle sound of my Type-S BOV can someone please help.
Old Nov 27, 2008 | 04:38 PM
MazdaManiac's Avatar
Uh, because when its on the lowest setting, you are bleeding off more air and the MAF/PCM doesn't like it.
Recirculate.
Old Nov 27, 2008 | 09:29 PM
chickenwafer's Avatar
Nope
On it's lowest setting the spring inside has no preload and it's bleeding off air.
Old Nov 27, 2008 | 09:34 PM
Spoolin8's Avatar
like said above.... At idle on the lowest setting the BOV is leaking air into the "atmosphere" this is not being read and tuned for therefor the A/F ratios are thrown off, It takes a little bit to find the right balance on the BOV so its closed at idle but opens enough to prevent compressor surge. I have done several turbo setups on cars before and i find that on most i have to open up the BOV itself and cut the spring inside to get it just right.
Old Nov 27, 2008 | 09:52 PM
Or just use an HKS or Syncronic.
Old Nov 27, 2008 | 11:00 PM
05rex8's Avatar
sold the 8... :(
HKS ftw
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
hufflepuff
May 30, 2016 10:45 AM
MolecularConcept
11
Sep 29, 2015 09:21 PM
Learners_Permit
Sep 27, 2015 07:38 PM
