springs v.s coilovers
Old Nov 18, 2008 | 10:04 AM
VS8's Avatar
VS8
4 Cylinder Rotary
well as some of you may know...i autocross my car and take my car to track occasionally
well i am stuck between the decision between springs (150) or just get coilovers (800)
i know that it will take me out of b stock either way...but i do want a lower car because i also go to alot of car shows....
my question is should i just get springs for the look or get coilovers for looks and performance...and also what class would i be in after installing the springs/coilovers
Old Nov 18, 2008 | 10:34 AM
dozer's Avatar
on his 3rd rx8
performance>looks, but with coilovers you will feel and see the difference...but then again anything is better than stock...
Old Nov 18, 2008 | 10:35 AM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
Cheap ($800) coil-overs can be worse than a good set of springs and shocks. If that is all the budget you have, a good set of springs with some Koni shocks would be your best option. Anything less and you are only doing it for looks.
Old Nov 18, 2008 | 11:41 AM
416to212's Avatar
Utopia Taco Bell
If you really were a points competitor you would'nt even be asking this question. A real racer would make it a point to stick it out in B-Stock (upgrade your structs)or upgrade to a coilover much more expensive, tunable and competitive.
I agree with ULLLOSE that cheap coilovers will most likely be more for show that performance.
For occassional tracking/autox and car shows, maybe a lower spring will keep you happy. Racing for you, like me, is probably just for fast fun and thrills so who really cares what class you run in.
BTW Where are my H-Techs? I sent you money, so send me my tracking info? LOL
Old Nov 18, 2008 | 01:27 PM
SouthFL's Avatar
The component which needs upgrading the most is the OEM damper. A set of springs with Koni or D-Spec dampers will yield very good increase in performance. As mentioned above, either go the spring/damper route, or save up for a good coilover set. I wouldn't waste money on springs alone to be used with the OEM damper.
Old Nov 18, 2008 | 01:29 PM
VS8's Avatar
VS8
4 Cylinder Rotary
this is first time ive used actual computer..i will get the info...
coilovers i would be gettin are tein basics
springs would be tein s tech
Old Nov 18, 2008 | 02:18 PM
Imp's Avatar
Imp
What's next?
Get some Koni Yellows (Off-The-Shelf aka. OTS) with the springs and you're at a much better starting point. Should something go wrong (and they hardly do with the Konis) you can have them repaired in the US. Or even re-valved to your liking.
Tein Basics, on the other hand, are overpriced, and only slightly better than stock. You'd have to get one of the higher end Teins to start hitting performance numbers that the OTS Konis aleady produce.
--kC
(I used to run Tein RAs on the WRX.... they were good, but couldn't get them re-valved here in the US like you can with the Konis.)
Old Nov 18, 2008 | 02:48 PM
SouthFL's Avatar
So, you've basically ignored all the above advice. Lol.
Old Nov 18, 2008 | 03:00 PM
SouthFL's Avatar
Read posts #4 and #5
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/spring-rates-other-basic-suspension-info-79096/
Old Nov 18, 2008 | 03:13 PM
VS8's Avatar
VS8
4 Cylinder Rotary
it was more of question than ignoring advice
even if it sounded like a statement
yurcivicsux
192
Sep 12, 2017 10:54 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
duworm
Oct 1, 2015 04:57 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
