A-pillar gauges?
Old Nov 17, 2008 | 04:27 PM
DoubleGoose's Avatar
FS Section Sniper
A-pillar gauges?
For anyone out there that has a-pillar gauges. Where did you wire them to for power? Thanks in advance
Old Nov 17, 2008 | 04:29 PM
Alucard's Avatar
RX8 Club OG
from the battery where else.... duh
hahaha jk...
Old Nov 17, 2008 | 04:44 PM
FS Section Sniper
another question also, i got an oil pressure gauge and a water temp gauge, is it necessary for me to get the RB oil sensor adapter and RB water sensor adapter?
Old Nov 17, 2008 | 05:01 PM
nuke0907's Avatar
Never Blend In
how else are you going to get the signal?
Old Nov 17, 2008 | 05:07 PM
FS Section Sniper
ok im gunna juss take that as a yes.
Old Nov 17, 2008 | 06:15 PM
yeah, you'll need sensor adapters for hooking those up. Look at my Sticky Thread in the Interior / Electronics forum
Old Nov 17, 2008 | 07:44 PM
FS Section Sniper
i see, nice work. so all the connections are the same even thought im putting them on the a pillar and not the ashtray? even where im hooking it up to power?
Old Nov 17, 2008 | 08:19 PM
NgoRX8's Avatar
if your wires are long enough.
or you can find a different source under the dash or at the fuse box.
Old Nov 17, 2008 | 08:21 PM
mysql's Avatar
Doppelgänger
i pulled power from inside the steering column. two power sources - always on and when car is on.
Old Nov 17, 2008 | 08:35 PM
05rex8's Avatar
sold the 8... :(
just use the fuse box...very easy to reverse if you end up putting car back to stock
Old Nov 17, 2008 | 08:54 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
i used fuse box and ground
Old Nov 17, 2008 | 08:55 PM
05rex8's Avatar
sold the 8... :(
^yup
Old Nov 17, 2008 | 09:19 PM
FS Section Sniper
i see. sounds good. hey, i know jedi already has the sticky for the DIY on the ashtray gauges, and i know theres a DIY for a pillar installation. but since mine is a different case ( i have a gauge pod and all), does anyone have or can make a DIY or like walk me through how to do this install? cuz id rather not spend more money at a shop if i can do it myself. i can supply pics of what i got to anyone that can help. lol.
cliffkemp
Dec 24, 2024 10:48 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
JantzenRX-8
Oct 4, 2015 11:30 PM
