p0107
Old Nov 13, 2008 | 05:06 PM
boizart1's Avatar
p0107
just got my car scanned on a friends scanner and I got back this one code only. What does it mean? He had a generic list and it said something about manifold something something pressure I didn't really understand it. Any idea what the code means???? I also have the light that looks like a car with squiggly lines underneath, I think it has something to do with traction control. It's always on and I can't turn it off. Any ideas on how to fix these 2 issues? Please help!!
Old Nov 13, 2008 | 05:15 PM
invasion08's Avatar
Diagnostic Trouble Code (DTC) P0107
DTC Definition: MAP/BARO Circuit Low Input
Old Nov 13, 2008 | 05:28 PM
boizart1's Avatar
what does that mean???
Old Nov 13, 2008 | 05:32 PM
Jon316G's Avatar
Grasshopper
This code is generated when the voltage drops below 0.2V.
Check the wiring and the harness to the sensor.
Old Nov 13, 2008 | 07:33 PM
boizart1's Avatar
where exactly is this sensor located?
Old Nov 13, 2008 | 07:40 PM
Jon316G's Avatar
Grasshopper
Do you see the battery cover at the bottom of my attached pic?
Old Nov 13, 2008 | 07:43 PM
Jon316G's Avatar
Grasshopper
this should help too
Old Mar 24, 2009 | 12:19 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
VERY INTERESTING. I removed my secondary air pump. I figured out that the big resistor on the pump mount was needed (fuel pump) but I didnt realize that there was a sensor on there. I have the same two issues. Solid DSC light and p0107 code. DSC must need this sensor. Will go hook it up.
I also have an RKE error. I have no idea what that is.
Old Mar 24, 2009 | 03:47 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Just as I thought. When I reinstalled the sensor both lights went away. The DSC error and the p0107 cel are tied together some how.
Old Mar 24, 2009 | 06:26 PM
REK 000039 has been reported as an unkown issue.
As far as we know... it doesn't effect performance.
Old Mar 26, 2019 | 03:47 AM
Santiago Crespo's Avatar
So changin the baro sensor worked?
Old Dec 1, 2019 | 07:21 PM
Fijibluefg2's Avatar
I LOVE this Forum
Thanks to this thread, I was able to easily locate the sensor and find a cut wire. Fixed it and eliminated the CEL.
I included a pic. hopefully it goes thru.
Danmn858
16
Oct 3, 2012 07:34 PM
EvisuMan
Jul 4, 2011 03:02 AM
RX8SHNKVI
May 16, 2011 07:22 AM
DarkLord7854
Sep 11, 2010 11:26 PM
TRU5hot
Series I Engine Tuning Forum
Feb 14, 2010 04:45 PM
