Greddy Turbo/ CELs
Old Nov 10, 2008 | 11:26 PM
J.Cab's Avatar
1st RX8 BNR Turbo Owner..
Greddy Turbo/ CELs
hey guys I just recently installed a Greddy Turbo and I am using the Greddy Emange Ultimate. However I can clear the CELs with the AP, but I wanted to know if anyone else has received CELs and if they are the same as mine.
On the AP it reads the 2 CELs as:
PCM P0130: O2 Sensor Circuit Malfunction (bank 1 sensor 1)
RKE P0039: it doesnt have an explaination for this one.
Can someone help me out as to if this is normal. I believe I may have a bad O2 Sensor, but as to the other one...who knows?
Old Nov 10, 2008 | 11:50 PM
Im_DANomite's Avatar
I love GOOOLD
is it unplugged?
Old Nov 11, 2008 | 12:31 PM
J.Cab's Avatar
Originally Posted by Im_DANomite
is it unplugged?
I am going to check to see if it is setup correctly. Maybe the wires were switched or something. But have you ever heard of this code popping up? RKE P0039
Old Nov 11, 2008 | 12:42 PM
Kane's Avatar
Senior Member
I do not have those with my EMU. So I am pretty positive something is wrong; including your AFR's from This weekend.
Old Nov 11, 2008 | 12:46 PM
J.Cab's Avatar
Kane, I was hoping you could chime in on this..anyways I am hoping that the guy who installed said the O2 Sensor was bad so he put another one in but he may have switched the wires therefore causing the numbers to read really really lean as opposed to rich. So today I am going to get under the car and check that out. Hope that would explain the "bucking" at above 5k maybe its going into like a safe mode and stopping the fuel.
Old Nov 11, 2008 | 12:52 PM
Kane's Avatar
Senior Member
That was my guess from Sunday - but I can't see anything so I am not 100% sure. The fact is you have no fuel trims at all; the AFR's are not moving from 14.7 even on start up; and the fuel cut feeling you are getting = no feedback to the PCM from the engine (my guess).
So maybe te O2 was installed wrong; wires were cut and shorted etc.... something is amiss.
Shankapotamus3
Mar 14, 2021 03:53 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Sep 26, 2015 12:30 PM
Forevermore
Sep 20, 2015 01:04 PM
