OMP issues
Old Nov 10, 2008 | 09:14 PM
whoneedspistons's Avatar
OMP issues
This past weekend I was participating in a track event and noticed some minor oil.... well after fishing around a bit it seems like there is some oil coming from the oil metering pump (not a ton of oil but a drips)... I was wondering if any of you have noticed that after pushing the car at an event? If so how did you fix it? etc...
I will be getting under the car this weekend to try and narrow down the problem. I did notice that it doesn't leak under daily driving...
Old Nov 10, 2008 | 09:21 PM
I8U's Avatar
I8U
Haven't seen that one before...take pics once you start playing around with it this weekend.
Old Nov 11, 2008 | 12:33 AM
I had problems with the front cover seal leaking...and the OMP gasket as well....
Both easily fixed
And neither leaked on the street......just on the track
Old Nov 11, 2008 | 06:11 AM
sounds like you may be onto something... i was assuming that it was the gasket. how would i know if its the front cover seal leaking?
Old Nov 11, 2008 | 11:20 AM
Check the front cover near the bottom of the eccentric shaft...it tends to spin up onto the OMP area and below. The OMP will usually leak just between itself and the housing... You might want to clean it off and see whether it leaks normal driving...it likely won't....and unless it is a lot more than mine was, it won't be a problem on the track
Old Nov 11, 2008 | 11:45 AM
if the front cover is leaking that would be cover under the Mazda warranty right?
Old Nov 11, 2008 | 11:58 AM
mac11's Avatar
Rotary , eh?
I would think if the OMP gasket is leaking it would also be covered under warranty.
Old Nov 11, 2008 | 12:20 PM
The OMP is not covered underwaranty because it considered an external component of the engine. I told him that this is a preventative measure so the motor did not have to be replaced. He then told me that the engine would be evaluated to determine the cause of failure. BTW the OMP was suppose to run 1500 bucks to replace I told him no thank you.
Old Nov 11, 2008 | 12:22 PM
mac11's Avatar
Rotary , eh?
Oh well. If it is the gasket that should be cheap and easy.
Old Nov 11, 2008 | 11:37 PM
the front seal is known to weep at track days.. the omp, not so much.
the omp gasket is copper.. you can snug it down a bit..
Old Nov 11, 2008 | 11:53 PM
The gasket on the discharge side where it goes into the lines are copper crush gaskets...the OMP to housing is an o-ring type seal
Old Nov 12, 2008 | 06:21 PM
olddragger's Avatar
just put some Mr Gasket-- instant one minute type in aerosol can from Advance Auto-- around the omp housing/oem omp gasket and viola--no more leaks. at the track. I had this pretty good and that fixed it right up.
OD
JimmyBlack
273
Feb 10, 2020 10:23 PM
Devil Doge
Sep 23, 2015 02:47 PM
RAE008
Sep 12, 2015 09:08 PM
tgaffner
Sep 7, 2015 08:49 PM
