AEM ugeo wireing - help
Boosted Kiwi
OK , so I have an AEM ugeo AFR guage that I bought second hand . Problem is the the clever person that uninstalled it cut off the plug that plugs into the sensor wire . I have 36 possible combinations .
If anyone has recently bought this guage but not installed it yet , could they look at the plug wires and see which colours match up to which .
thanks
Brett
thanks
Brett
Boosted Kiwi
Here is where it is cut - there are black,red, white,green,brown and orange wires
Those wires need to connect to this plug - sorry don't have the colours as it is installed under my car atm.
I need to know what colours go to which pins on the plug . I think i will end up soldering them on as i can't get hold of another plug .
Cheers
Cheers
So it's the plug from the actual Bosch AFR sensor that goes into the back of the gauge that is cut, correct?
Shouldn't it just match up color wise?
If not, Let me see if I can find my instruction booklet, otherwise I can pull it apart tomorrow.
Boosted Kiwi
yes that's the one - there are only 4 wires on the actual sensor plug though , with 6 going to the guage .
Have checked the install instructions to no avail ....
cheers
cheers
if you where to plug in the mated connector to the plug you posted in picture #2, the colors go from top-down, left to right as...
Top Row - Black -> Brown -> Orange
Bottom - Green -> White -> Red
Or you could just contact AEM and order part number 35-3400
Boosted Kiwi
PM coming your way .
Boosted Kiwi
thanks heaps for the info
Danield97
Sep 30, 2015 05:59 PM
Learners_Permit
Sep 27, 2015 07:38 PM
