greekRX-8
12-05-2003, 12:17 PM
I thing that one issue of the RX-8 is the ''long'' gearing. Pls check the graph of the normal gearbox and compare it with the HONDA CIVIC TYPE R 200 bhp and the one with shorter final gear. CIVIC TYPE R 200 bhp is sold here in europe and along with the ACCURA RSX are the only cars equiped with high reving engines so we can compare them. You can get the QSPEED calculator from www.quaife.co.uk (http://www.quaife.co.uk) I hope that tuners are working for a shorter final gear or even better with shorter gear ratios. If anyone know something pls post http://www.quaife.co.uk/downloads/QSpeedCalc.exe Gearbox:- RX - 8
Tyre:- 225 45 18
Top Gear gives 20.619 MPH/1000 RPM and a top speed of 185.571 MPH at 9000 RPM
Engine speeds in top gear:-
30 MPH = 1455 RPM 40 MPH = 1940 RPM 50 MPH = 2425 RPM 60 MPH = 2910 RPM
70 MPH = 3395 RPM 80 MPH = 3880 RPM 90 MPH = 4365 RPM 100 MPH = 4850 RPM
Top Speed in 1 gear = 41.605 MPH
And changes into 2 gear at 5431 RPM dropping 3569 RPM
Top Speed in 2 gear = 68.945 MPH
And changes into 3 gear at 6104 RPM dropping 2896 RPM
Top Speed in 3 gear = 101.648 MPH
And changes into 4 gear at 6942 RPM dropping 2058 RPM
Top Speed in 4 gear = 131.791 MPH
And changes into 5 gear at 7582 RPM dropping 1418 RPM
Top Speed in 5 gear = 156.437 MPH
And changes into 6 gear at 7587 RPM dropping 1413 RPM
Top Speed in 6 gear = 185.571 MPH
Gearbox:- RX - 8 17/80
Tyre:- 225 45 18
Top Gear gives 19.474 MPH/1000 RPM and a top speed of 175.262 MPH at 9000 RPM
30 MPH = 1541 RPM 40 MPH = 2054 RPM 50 MPH = 2568 RPM 60 MPH = 3081 RPM
70 MPH = 3595 RPM 80 MPH = 4108 RPM 90 MPH = 4622 RPM 100 MPH = 5135 RPM
Top Speed in 1 gear = 39.294 MPH
Top Speed in 2 gear = 65.115 MPH
Top Speed in 3 gear = 96.001 MPH
Top Speed in 4 gear = 124.470 MPH
Top Speed in 5 gear = 147.746 MPH
Top Speed in 6 gear = 175.262 MPH
Gearbox:- TYPE R
Tyre:- 205 45 17
Top Gear gives 20.480 MPH/1000 RPM and a top speed of 172.031 MPH at 8400 RPM
30 MPH = 1465 RPM 40 MPH = 1953 RPM 50 MPH = 2441 RPM 60 MPH = 2930 RPM
70 MPH = 3418 RPM 80 MPH = 3906 RPM 90 MPH = 4395 RPM 100 MPH = 4883 RPM
Top Speed in 1 gear = 34.221 MPH
And changes into 2 gear at 4810 RPM dropping 3590 RPM
Top Speed in 2 gear = 59.767 MPH
And changes into 3 gear at 5994 RPM dropping 2406 RPM
Top Speed in 3 gear = 83.752 MPH
And changes into 4 gear at 6355 RPM dropping 2045 RPM
Top Speed in 4 gear = 110.698 MPH
And changes into 5 gear at 6720 RPM dropping 1680 RPM
Top Speed in 5 gear = 138.373 MPH
And changes into 6 gear at 6757 RPM dropping 1643 RPM
Top Speed in 6 gear = 172.031 MPH
Tyre:- 225 45 18
Tyre:- 225 45 18
Gearbox:- TYPE R
Tyre:- 205 45 17
