Exhaust
Old Oct 29, 2008 | 02:51 PM
Samaroo's Avatar
Exhaust
I just purchased a 2005 GT 6 speed. The 4206F recall had not been preformed but will be done on Friday. Since I'm new to the rotary engine my question has to do with the exhaust. Originally I thought the car was misfiring, it still might be, so I ask does the exhaust send out a puff of exhuast with each turn of the engine? You can hear it and feel the extra burst of exhuast every few seconds. Am I crazy or is this wrong?
thanks!
Old Oct 29, 2008 | 02:54 PM
hey Samaroo, welcome to the addiction.
Extra burst of exhaust? Nope, that's definitely not standard on an rx-8. Can you explain it a little more?
Are you seeing smoke? Could just be your car misfiring which should be taken care of by the 4206F recall if the ignition coils are going bad. (or spark plugs)
Old Oct 29, 2008 | 02:57 PM
Samaroo's Avatar
As the engine runs the flow from the exhaust is steady then every few seconds you hear and can feel (hard to explain but what seems like a PUFF, then back to normal flow of exhaust then again a PUFF). I know it's strange, but if it was misfiring wouldn't I notice that in loss of power...none of that going on.
Old Oct 29, 2008 | 03:01 PM
exhaust flow is pretty constant.
PUFF, then back to normal, then PUFF? Clogged cat maybe?
and yes, either bad coils or clogged cat would result in some loss of performance.
Is it maybe just the exhaust backfiring as your'e shifting that your'e hearing? That can happen with quick shifts at high RPM's
Old Oct 29, 2008 | 03:04 PM
Samaroo's Avatar
The only time I notice it is when the car is sitting at idle. It is the same at start up and then after a drive. There is no smoke associated with it. I'll mention it when I drop it off Friday at the dealer, if I am missing some power I sure have not noticed it.
Old Oct 29, 2008 | 03:05 PM
luis@championsmotorsports's Avatar
sounds like a miss fire,loading up and clearing up,misfires not always happen under power,ive seen them only at idle as well,once you start to rev up the computer compensates for its air fuel delivery,.at idle its got to be dead on,any little hickup will cause possibly what you are hearing,or like jedi said could be bad coils,too,it may be solved when the recall is performed
Old Oct 29, 2008 | 03:17 PM
Samaroo's Avatar
Old Oct 29, 2008 | 03:26 PM
CyberPitz's Avatar
Huge hole is huge
Every single car I've ever owned has caused this except my RX-8 *Then again, all my cars have been 80's cars...haha* So yeah, I'd say you should be good with the coils swap.
Old Oct 29, 2008 | 04:57 PM
04RX8man's Avatar
Rotary Powered Countryboy
UI think i know what you're saying mine does a little but not noticable it it's bad enough you're really noticing then yeah i would say coils..
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
arexatemate
Oct 28, 2019 08:16 AM
mdl0209
May 23, 2019 05:46 PM
Jb4ker96
Sep 27, 2015 10:06 PM
