Engine bay foam
Old Oct 26, 2008 | 01:06 PM
CompMan's Avatar
iDüber
Engine bay foam
I see a lot of Rx8's with the Foam that surrounds the engine bay removed. I wanted to rip all mine out since it makes it look a lot better. My question is if I remove that foam like substance is it going to damage anything?
Thanks guys.
This is a random rx8 with the foam
Old Oct 26, 2008 | 03:00 PM
Velislide's Avatar
Your intake scares me.
But yea, I was also thinking about removing the hood foam, would imagine that would reduce under the hood heat, the engine will make more noise but who cares about that when its a rotary?
Old Oct 26, 2008 | 03:02 PM
scwchapman's Avatar
I think, and I may be wrong, but I believe it is mostly for noise insulation and I don't believe it should affect temperature very much. The hood will probably get hotter since it is being more directly exposed to the engine but I don't believe it will affect it negatively. I say go for it and tell us what you think!
Old Oct 26, 2008 | 03:27 PM
tunerwannab's Avatar
That intake looks like it has one of those home made fuel cells on it. Or I was thinking a water or methonal injection but I have never seen what those look like.
Old Oct 26, 2008 | 03:34 PM
SayNoToPistons's Avatar
Wheels, not rims!!
The "foam" on the hood is supposed to drop down on your engine in case there's an engine fire to help smother it out.
Old Oct 26, 2008 | 03:56 PM
BOV
Old Oct 26, 2008 | 04:04 PM
scwchapman's Avatar
If you don't mind me asking, how exactly does that work? I just don't understand it and I don't like not knowing things about my car.
Old Oct 26, 2008 | 05:23 PM
CompMan's Avatar
iDüber
I just tore it all out lol. Still working!
and that is not my engine bay!!!
Thats my engine bay^
Attached Thumbnails Engine bay foam-dsc02717.jpg   Engine bay foam-dsc02716.jpg
Old Oct 26, 2008 | 06:26 PM
scwchapman's Avatar
did the stuff weigh much at all? I would imagine no? Do you notice any different in sound however or temperature of the hood or on the temp gauge after a spirited drive?
Old Oct 26, 2008 | 06:36 PM
04RX8man's Avatar
Rotary Powered Countryboy
I think it is just there for noise won't help too much for heat i don't think
Old Oct 26, 2008 | 06:49 PM
Those are heat AND flame shields.
I hope u keep them.
Rotr8's Avatar
whines all the way home
Internal ambient temps will benefit greatly with removing the seudo fire blanket, but since Ive actually had my cat catch on fire im keeping it....
Old Oct 26, 2008 | 06:52 PM
CompMan's Avatar
iDüber
It weighed in at about a pound lol
I noticed a slight increase in Engine noise when your outside the car, standing up front. You can here that little weeeee noise that we all have a little bit clearer.
The temperature gauge did not go up what so ever. and I drove it non stop for like an hr, hard.
Old Oct 26, 2008 | 06:53 PM
scwchapman's Avatar
YOU'RE CAT CAUGHT ON FIRE!?!?!
only kidding. So basically it helps a bit in noise reduction, doesn't weight much to make a difference by removing it, and ultimately is a safety feature, so best to leave it on?
Old Oct 26, 2008 | 06:54 PM
CompMan's Avatar
iDüber
I guess, but its ugly.
It looks a ton better.
Old Oct 26, 2008 | 06:59 PM
scwchapman's Avatar
I may try it out for a few days if I can take it off cleanly and put it back on cleanly. I'll post before and after pics if I do.
Old Oct 26, 2008 | 07:11 PM
Wheels, not rims!!
The plastic clips melt away when there is an engine fire. The fabric drops and smothers the engine bay.
Old Oct 26, 2008 | 07:12 PM
scwchapman's Avatar
Ah. interesting. Thanks
Old Oct 26, 2008 | 07:35 PM
Originally Posted by dannobre
BOV
I noticed that, I meant more of the unit by the coolant bottle and the hoses connected to it. I wasn't sure what it was. Maby an oil catch can?
Old Oct 26, 2008 | 07:44 PM
Yup...catch can
BigMikeATL
May 26, 2016 12:31 AM
uZu
Dec 30, 2015 12:35 PM
rx8inator
Sep 1, 2015 07:18 PM
rx8inator
Aug 14, 2015 10:53 PM
iSki123
Jul 27, 2015 12:41 PM
